Updated on 2024-08-07 GMT+08:00
Comparing Versions
The following table lists the differences between the old and new consoles.
Table 1 Comparing versions
Difference
Old
New
Two-factor authentication
Not supported
Supported
Configuration of retries for HTTP&HTTPS backend services
Not supported
Supported
API import
For registering APIs
For registering APIs or creating API groups
API debugging with a custom body
Not supported
Supported
API details page
Average
Highly integrated
API topology
Supported
Not supported
Visual display of API policies
Not supported
Supported
Creating policy by script
Not supported
Supported
Plug-in type
CORS, HTTP response header management, request throttling
CORS, HTTP response header management, request throttling 2.0, Kafka log push, circuit breaker. These plug-ins are managed together with traditional policies.
SSL certificate management
Not supported
Supported
Creating server groups for load balance channels
Not supported (VPC channels)
Supported
Health check switch for load balance channels
Supported
Display of standby nodes and statuses for load balance channels
Supported
Apps
Supported
Now called "credentials"
Credential quota policies
Not supported
Supported
Access control policies
Not supported
Supported
API monitoring
Provided on the Dashboard page
Now called "API Monitoring"
Subdomain name
Supported
Now called "debugging domain name"
Variable management
Variables
Now called Environment Variables
Gateway selection in left navigation pane
Not supported
Supported
Gateway tags
Not supported
Supported
Account ID-based access control
Not supported
Supported
Cloning APIs
Not supported
Supported
custom_log
Not supported
Supported
Third-party authentication policy
Not supported
Supported
OpenAPI 3.0
Not supported
Supported
Client request customization
Not supported
Supported
HTTP-to-HTTPS auto redirection
Not supported
Supported
CA certificate
Not supported
Supported
