Help Center/ API Gateway/ User Guide/ Managing APIs/ Configuring API Parameter Orchestration Rules
Updated on 2025-01-10 GMT+08:00
APIG supports API parameter orchestration. You can configure different algorithm rules to map new request parameters and values.
Creating an Orchestration Rule
  1. Go to the APIG console.
  2. Select a dedicated gateway at the top of the navigation pane.
  1. In the navigation pane, choose API Management > API Policies.
  2. Click the Orchestration Rules tab.
  3. Click Create Rule and configure the parameters based on the following table.
    Table 1 Rule configuration
    Rule Name
    Enter a rule name. Start with a letter and use only letters, digits, and underscores (_). 3 to 64 characters.
    Orchestration Policy
    Select a policy.
    • list: Listed values are mapped to other values.
    • range: Values in the range are mapped to other values.
    • hash: Request header values are mapped to new ones after hash calculation.
    • hash_range: hash values are generated using the request parameters for range orchestration.
    • none_value: If the request parameter is empty, the mapping value of the none_value policy is returned.
    • default: If request parameters cannot match any orchestration rule, the mapping value of the default policy is returned.
    • head_n: Intercept the first n characters of the string (If n is greater than the length of the string, the complete parameter value is returned.) as a temporary parameter pending orchestration for the next rule.
    • tail_n: Intercept the last n characters of the string (If n is greater than the length of the string, the complete parameter value is returned.) as a temporary parameter pending orchestration for the next rule.
    Preprocessing
    Mandatory when Orchestration Policy is set to list, range, hash, hash_range, head_n, or tail_n.
    Whether the rule is a preprocessing one. A preprocessing rule generates a value as a temporary parameter pending orchestration for the next rule.
    Parameter Name
    Mandatory when Preprocessing is disabled or Orchestration Policy is set to none_value or default.
    Enter the parameter name after orchestration. Start with a letter and use only letters, digits, and hyphens (-). 1 to 128 characters.
    Parameter Type
    Select a parameter type.
    • string
    • number
    Parameter Location
    Select a parameter location.
    • header
    • query
    Mapping
    Mandatory when Orchestration Policy is set to list, range, hash_range, none_value, or default.
    Enter the mapping information. Start with a letter and use only letters, digits, underscores (_), and hyphens (-). 1 to 128 characters. Use commas (,) to separate multiple parameter values. A maximum of 3,000 parameters are supported.
    You can click Add Mapping to add new mappings.
    • Request Parameter Value Before Orchestration
      • When Orchestration Policy is set to list, enter the request parameter value before orchestration.
      • When Orchestration Policy is set to range or hash_range, enter the start value and end value of the range.
    • Request Parameter Value After Orchestration: Enter the request parameter value after orchestration.
    Length
    Mandatory when Orchestration Policy is set to head_n or tail_n.
    Length of the character string to be intercepted. The value ranges from 1 to 100.
  4. Click OK.
