Monitoring Metrics
Introduction
This section describes the metrics that APIG reports to the Cloud Eye service. You can view metrics and alarms by using the Cloud Eye console.
If a metric is not supported by your gateway, submit a service ticket to upgrade the gateway to the latest version.
Namespace
SYS.APIC
Metrics
Metric ID |
Metric Name |
Description |
Value Range |
Unit |
Conversion Rule |
Monitored Object (Dimension) |
Monitoring Period (Minute) |
throttled_calls |
Throttled API Calls |
Number of API calls that are throttled. |
≥0 |
Times/min |
None |
Dedicated gateway (instance_id) |
1 |
requests |
API Calls |
Number of times that an API has been called |
≥0 |
Times/min |
None |
1 |
req_count_error |
Total Errors |
Total number of API errors |
≥0 |
Times/min |
None |
API (instance_id and api_id) |
1 |
req_count_5xx |
5xx Responses |
Number of API calls resulting in 5xx responses |
≥0 |
Times/min |
None |
1 |
req_count_4xx |
4xx Responses |
Number of API calls resulting in 4xx responses |
≥0 |
Times/min |
None |
1 |
req_count_2xx |
2xx Responses |
Number of API calls resulting in 2xx responses |
≥0 |
Times/min |
None |
1 |
req_count |
API Calls |
≥0 |
Times/min |
None |
1 |
output_throughput |
Outgoing Traffic |
Outgoing traffic of the API |
≥0 |
Byte |
1000(SI) |
1 |
max_latency |
Maximum Latency |
Maximum latency of the API |
≥0 |
ms |
None |
1 |
max_latency |
Maximum Latency |
≥0 |
ms |
None |
1 |
input_throughput |
Incoming Traffic |
Incoming traffic of the API |
≥0 |
Byte |
1000(SI) |
1 |
error_5xx |
5xx Responses |
≥0 |
Times/min |
None |
1 |
error_4xx |
4xx Responses |
≥0 |
Times/min |
None |
1 |
avg_latency |
Average Latency |
Average latency of the API |
≥0 |
ms |
None |
1 |
avg_latency |
Average Latency |
≥0 |
ms |
None |
1 |
node_system_load |
Node System Load |
Load details of a gateway node on the data plane. 1 means low water level, 2 means medium water level, and 3 means high water level. |
1, 2, 3 |
count |
None |
Gateway node (node_ip) |
1 |
node_cpu_usage |
Node CPU Usage |
CPU usage details of a gateway node on the data plane |
≥0 |
None |
1 |
node_memory_usage |
Node Memory Usage |
Memory usage details of a gateway node on the data plane |
≥0 |
None |
1 |
Dimension
Key |
Value |
instance_id |
Dedicated gateway |
instance_id, node_ip |
Dedicated gateway node |
instance_id, api_id |
API |
