Calling APIs
Obtaining APIs and Documentation
Before calling APIs, obtain the request information from the API provider, including the access domain name, protocol, method, path, and request parameters.
Obtain APIs: from your company or from a partner
Obtain related documentation
- For APIs obtained from Huawei Cloud, obtain documentation from the Help Center.
The authentication information to be obtained varies with the API authentication mode.
- App authentication:
- Signature authentication: Obtain the key and secret (or client AppKey and AppSecret) of the app authorized for the API from the API provider as well as the SDK for calling the API.
- Simple authentication: Obtain the AppCode of the app authorized for the API from the API provider.
- Other authentication modes: Obtain the key and secret (or client AppKey and AppSecret) of the app authorized for the API from the API provider.
- IAM authentication: The account credential (token or AK/SK obtained with the account and password) obtained on the cloud service platform is used for authentication. If the AK/SK is used for authentication, you also need to obtain the SDK from the API provider for calling the API.
- Custom authentication: Obtain the custom authentication information to be carried in the request parameters from the API provider.
- None: No authentication information is required.
Calling an API
This section describes only the configuration of the request path and authentication parameters. For other parameters, such as timeout and SSL, configure them as required. To avoid service loss due to incorrect parameters, configure them by referring to the industry standards.
- Set the request path.
Request Parameter Configuration
Calling an API with a domain name
Call the API using the subdomain name allocated to the API group or a domain name bound to the group. No additional configuration is required.
Calling an API in a non-DEFAULT group with an IP address
To use an IP address to call an API that does not use app authentication in a non-DEFAULT group, add the header parameter host.
- Set the authentication parameters.
Authentication Mode
App authentication (with a signature)
Use the SDK to sign API requests. For details, see Calling APIs Through App Authentication.
App authentication (through simple authentication)
Add the header parameter X-Apig-AppCode and set the parameter value to the AppCode obtained in Obtaining APIs and Documentation. For details, see Getting Started.
IAM authentication (with a token)
Obtain a token from the cloud platform and carry the token in API requests for authentication. For details, see Token Authentication.
IAM authentication (with AK/SK)
Use an SDK to sign API requests. For details, see AK/SK Authentication.
Carry authentication information in API request parameters for authentication.
None
Call APIs without authentication.
