Updated on 2025-12-09 GMT+08:00
x-apigateway-match-mode
Meaning: Request URL matching mode, which can be NORMAL or SWA.
Scope of effect: Operation Object (2.0)/Operation Object (3.0)
Example:
paths:
  '/path':
    get:
      x-apigateway-match-mode: 'SWA'
Table 1 Parameter description
Mandatory
Type
Yes
String
API matching mode. The options include SWA and NORMAL.
  • SWA: prefix match. For example, both /prefix/foo and /prefix/bar match /prefix, but /prefixpart does not match.
  • NORMAL: absolute match. For example, /prefix/foo can be matched only by /prefix/foo.
