Help Center>
API Gateway>
User Guide (ME-Abu Dhabi Region)>
Getting Started>
Opening APIs>
Creating an API Group
Updated on 2023-05-09 GMT+08:00
- Log in to the APIG console.
- Select a gateway you created.
- In the navigation pane, choose API Management > API Groups.
- Choose Create API Group > Create Directly.
Figure 1 Configuring API group information
Table 1 API group information Parameter
Name
API group name. It is recommended that you enter a name based on naming rules to facilitate search.
Description of the API group.
- Click OK. The system automatically allocates a debugging domain name to the API group. APIs in the group can be debugged using the domain name.
Parent topic: Opening APIs
