Updated on 2023-05-09 GMT+08:00
Resetting Secret
Reset the secret of a credential as necessary. After resetting, the original secret becomes invalid and APIs to which the credential is bound cannot be called. To call the APIs, update the secret in the SDK. The key is unique and cannot be reset.
  1. Log in to the APIG console.
  2. Select a gateway at the top of the navigation pane.
  1. In the navigation pane, choose API Management > Credentials.
  1. Click the name of the target credential.
  2. Click Reset Secret.
  3. Click OK.
