Help Center/ API Gateway/ User Guide/ Shared Gateway (for Existing Users)/ API Group Management/ Deleting an API Group
Updated on 2024-04-03 GMT+08:00
You can delete an API group if you do not require it.
API groups that contain APIs cannot be deleted.
You have created an API group.
- Access the shared gateway console.
- In the navigation pane, choose API Publishing > API Groups.
- Delete an API group. You can use one of the following methods:
- In the Operation column of the target API group, choose More > Delete.
- Click the name of the target API group, and click Delete Group in the upper right corner of the displayed API group details page.
- Enter DELETE and click Yes.
Parent topic: API Group Management
