- What's New
- Function Overview
Billing
- Billing Overview
- Billing Modes
- Billing Items
- Billing Examples
- Changing the Billing Mode
- Renewing Your Subscription
- Bills
- Arrears
- Billing Termination
- Cost Management
Billing FAQs
- How Is SecMaster Billed?
- Can I Use SecMaster for Free?
- How Do I Change or Disable Auto Renewal for SecMaster?
- Will SecMaster Be Billed After It Expires?
- How Do I Renew SecMaster When It Is About to Expire?
- Where Can I Unsubscribe from SecMaster?
- Where Can I View the Remaining Quotas of Security Data Collection and Security Data Packages?
- Getting Started
User Guide
- Buying SecMaster
- Authorizing SecMaster
- Checking Security Overview
- Workspaces
- Viewing Purchased Resources
Security Governance
- Security Governance Overview
- Security Compliance Pack Description
- Authorizing SecMaster to Access Cloud Service Resources
- Subscribing to or Unsubscribing from a Compliance Pack
- Starting a Self-Assessment
- Viewing Security Compliance Overview
- Viewing Evaluation Results
- Viewing Policy Scanning Results
- Downloading a Compliance Report
- Security Situation
- Resource Manager
- Risk Prevention
- Threat Operations
- Security Orchestration
Playbook Overview
- Ransomware Incident Response Solution
- Attack Link Analysis Alert Notification
- HSS Isolation and Killing of Malware
- Automatic Renaming of Alert Names
- Auto High-Risk Vulnerability Notification
- Automatic Notification of High-Risk Alerts
- Auto Blocking for High-risk Alerts
- Real-time Notification of Critical Organization and Management Operations
Settings
- Data Integration
Log Data Collection
- Data Collection Overview
- Adding a Node
- Configuring a Component
- Adding a Connection
- Creating and Editing a Parser
- Adding and Editing a Collection Channel
- Managing Connections
- Managing Parsers
- Managing Collection Channels
- Managing Collection Nodes
- Viewing Collection Nodes
- Partitioning a Disk
- Logstash Configuration Description
- Connector Rules
- Parser Rules
- Upgrading the Component Controller
- Customizing Directories
- Permissions Management
- Key Operations Recorded by CTS
Best Practices
Log Access and Transfer Operation Guide
- Solution Overview
- Resource Planning
- Process Flow
- (Optional) Step 1: Buy an ECS
- (Optional) Step 2: Buy a Data Disk
- (Optional) Step 3: Attach a Data Disk
- Step 4: Create a Non-administrator IAM User
- Step 5: Configure Network Connection
- Step 6: Install the Component Controller (isap-agent)
- Step 7: Install the Log Collection Component (Logstash)
- (Optional) Step 8: Creating a Log Storage Pipeline
- Step 9: Configure a Connector
- (Optional) Step 10: Configure a Log Parser
- Step 11: Configure a Log Collection Channel
- Step 12: Verify Log Access and Transfer
- Credential Leakage Response Solution
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Alert Management
- Incident Management
- Indicator Management
- Playbook Management
- Alert Rule Management
- Playbook Version Management
- Playbook Rule Management
- Playbook Instance Management
- Playbook Approval Management
- Playbook Action Management
- Incident Relationship Management
- Data Class Management
- Workflow Management
- Data Space Management
- Pipelines
- Workspace Management
- Metering and Billing
- Metric Query
- Baseline Inspection
- Appendix
- FAQs
More Documents
- Buying SecMaster
- Security Overview
- Workspaces
- Resource Manager
- Risk Prevention
Threat Operations
- Alert Management
- Intelligent Modeling
Security Analysis
- Security Analysis Overview
- How to Use Security Analysis
- Configuring Indexes
- Querying and Analyzing Data
- Downloading Logs
Query and Analysis Statements - SQL Syntax
- Basic Syntax
- Limitations and Constraints
- Query Statements
- Syntax of Analysis Statements
- Analysis Statements - SELECT
- Analysis Statements - GROUP BY
- Analysis Statements - HAVING
- Analysis Statements - ORDER BY
- Analysis Statements - LIMIT
- Analysis Statements - Functions
- Analysis Statements - Aggregate Functions
- Quick Query
- Quickly Adding a Log Alarm Model
- Charts
- Managing Data Spaces
- Managing Pipelines
- Data Consumption
- Data Delivery
- Data Monitoring
- Security Orchestration Overview
- Built-in Playbooks and Workflows
- Security Orchestration Process
- (Optional) Configuring and Enabling a Workflow
- Configuring and Enabling a Playbook
- Operation Object Management
- Playbook Orchestration Management
- Layout Management
- Plug-in Management
- Settings
Product Consulting
- Why Is There No Attack Data or Only A Small Amount of Attack Data?
- Where Does SecMaster Obtain Its Data From?
- What Are the Dependencies and Differences Between SecMaster and Other Security Services?
- What Are the Differences Between SecMaster and HSS?
- How Do I Update My Security Score?
- How Do I Handle a Brute-force Attack?
- Data Synchronization and Consistency
- How Do I Grant Permissions to an IAM User?
- Purchase Consulting
- Troubleshooting
Product Consulting
- Change History
- Security Overview
- Workspaces
- Resource Manager
Risk Prevention
Baseline Inspection
- Baseline Inspection Overview
- Creating a Custom Check Plan
- Starting an Immediate Baseline Check
- Viewing Check Results
- Handling Check Results
- Viewing Compliance Packs
- Creating a Custom Compliance Pack
- Importing and Exporting a Compliance Pack
- Viewing Check Items
- Creating a Custom Check Item
- Importing and Exporting Check Items
- Vulnerability Management
- Policy Management
Baseline Inspection
Threat Operations
- Alert Management
- Security Analysis
- Data Delivery
- Layout Management
- Settings
Product Consulting
- Issues About Data Synchronization and Data Consistency
- About Data Collection Faults
Product Consulting
- Change History
Creating, Copying, and Editing a Categorical Mapping
Classification and mapping are to perform class matching and field mapping for cloud service alerts.
This section walks you through on how to create, edit, and copy a classification and mapping.
Creating a Categorical Mapping
- Click in the upper part of the page and choose Security > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
Figure 1 Workspace management page
- In the navigation pane on the left, choose Security Orchestration > Objects. On the page displayed, click the Classify&Mapping tab.
Figure 2 Classify&Mapping tab page
- On the Classify&Mapping page, click Create.
- On the Create Categorical Mapping page, set categorical mapping parameters.
Figure 3 Create Categorical Mapping page
- In the Basic Parameters area on the left, configure basic information about the categorical mapping. For details about the parameters, see Table 1.
- In the Data Source area on the left, select the data source for categorical mapping.
When Data Source is set to Upload JSON file, you need to click to upload the JSON file and upload the JSON file.
- On the Classify tab page on the right, select a classification mode and set related parameters.
- After the classification configuration is complete, click at the upper right corner of the page to save the configuration.
- On the Mapping tab page in the right pane, select a mapping mode and set related parameters.
- After categorical mapping is complete, click at the upper right corner of the page to save the configuration.
- On the Preprocessing tab on the right, set preprocessing mapping parameters.
- Click at the upper right corner of the page to save the configuration.
Copying a Categorical Mapping
Figure 4 Workspace management page
Figure 5 Classify&Mapping tab page
- On the Classify&Mapping page, click Clone in the Operation column of the target categorical mapping.
- In the displayed dialog box, enter the name for replicated mapping and click OK.
Figure 6 Workspace management page
Figure 7 Classify&Mapping tab page
- On the Classify&Mapping page, click the target categorical mapping name to go to the edit page.
- On the Edit Categorical Mapping page, set parameters.
Table 2 Configuring basic information Parameter
Name
Name of a user-defined categorical mapping.
Data Category
This field cannot be edited.
Description of the custom categorical mapping.
- In the Data Source area on the left, select the data source for the categorical mapping.
If Data Source is set to Upload JSON file, you need to click Upload JSON file and upload the JSON file.
- On the Classify tab on the right, select a classification mode and set related parameters.
- On the Mapping tab on the right, select a mapping mode and set related parameters.
- After the categorical mapping is complete, click at the upper right corner of the page to save the configuration.
