User Guide
- Preparatory Work
- Introducing the DLV Console
- How-Tos
- Managing Workspaces
- Creating Data Connections
- Creating Screens
- Developing Screens
- Managing Screens
- Managing Layers
Data Connection Management
- Data Connection Overview
- Using Static Data Sources
- Creating API Data Connections
- Creating CSV File Data Connections
- Creating Object Storage Service Data Connections
- Creating Data Warehouse Service Data Connections
- Creating Data Lake Insight Data Connections
- Creating MRS Hive Data Connections
- Creating MRS SparkSQL Data Connections
- Creating ClickHouse Data Connections
- Creating RDS for MySQL Data Connections
- Creating RDS for PostgreSQL Data Connections
- Creating RDS for SQL Server Data Connections
- Creating RDS for GaussDB Data Connections
- Creating GeminiDB Influx API Data Connections
- Creating Cloud Search Service Data Connections
- Creating DDM Data Connections
- Creating Oracle Data Connections
- Creating MySQL Data Connections
- Creating PostgreSQL Data Connections
- Creating SQL Server Data Connections
- Creating Elasticsearch Data Connections
- Editing Data Connections
- Searching for Data Connections
- Deleting Data Connections
- Managing Components
- Component Guide
- Screen Combination
- Integrating DLV into Third-Party Systems
- Change History
- Developer Guide
- API Reference
- What Is DLV Used For?
- Regions and AZs
- Can I Quickly Create a DLV Screen Using a Template?
- Can DLV Connect to Data Sources Through APIs?
- What Types of Data Connections Are Supported in DLV?
- How Do I Configure a CSV Data Source?
- How Do I Use the Interaction Function?
- What Can I Do If a Component Cannot Be Completely or Normally Displayed?
- How Do I Query Data Formats Supported by Different Components?
- What Can I Do When the WebGL Component Breaks Down?
More Documents
- Preparatory Work
- How-Tos
- Creating Screens
- Managing Screens
- Managing Layers
- Creating API Gateway Data Connections
- Creating a DAYU Data Connection
- Managing VPC Connections
- Component Guide
- What Is DLV?
- Regions and AZs
- How Many Screens Can I Create in DLV?
- Change History
- API Reference (ME-Abu Dhabi Region)
- Developer Guide (ME-Abu Dhabi Region)
On this page
Show all
Help Center/
Data Lake Visualization/
User Guide (ME-Abu Dhabi Region)/
Component Guide/
Text/
Carousel Table
Carousel Table
This section describes parameters of a carousel table component.
Pattern
- Size/Position
- Size: width and height of the component. Unit: pixel.
- Position: position where the component is located in the canvas. Unit: pixel.
Figure 1 Carousel table
- Global Style
- Table Rows: to set the number of rows to be displayed in the table by entering a value or clicking .
- Rotate: if Rotate is selected, the content in the table is played in rotation. If this parameter is not selected, the table content is not played in rotation. If the number of rows in the table exceeds the specified number, a scroll bar is displayed. You can slide the scroll bar to view the table data.
- Animation Type: to select an animation type from the drop-down list. The value can be Flip, Marquee, or Beat.
- Interval: to set the interval for rotating the content in the table by entering a value or clicking .
- Automatic Line Feed: If this option is selected, the content in the cell is automatically fed. If this parameter is not selected, the cell content is not automatically wrapped. If the content is too long, only part of the content is displayed.
- Font: to set the font style of the table text from the drop-down list.
- Table Header
- Table Header: to show or hide the table header by clicking or .
- Row Height: to set the row height of the table header by entering a value or dragging .
- Background Color: to set the background color of the table header by clicking the color editor.
- Alignment: alignment mode of the text in the table header. The value can be Align center, Left, or Right.
- Font: to select a font style from the drop-down list.
- Font Color: to set the font color by clicking the color editor.
- Font Size: to select a font size from the drop-down list.
- Font Width: to select a font width from the drop-down list.
- Row Settings
- Odd-numbered Row Background: to set the background color of the odd-numbered rows in the table by clicking the color editor.
- Even-numbered Row Background: to set the background color of the even-numbered rows in the table by clicking the color editor.
- SN
- SN: to show or hide the SN by clicking or .
- Background Color: to set the background color of the SN by clicking the color editor.
- Round Corner: to set the round corner angle of the SN icon by entering a value or clicking .
- Column Width Ratio (%}: to set the width of the SN column by entering a value or dragging .
- Radius: to set the radius size of the SN icon by entering a value or dragging .
- Font Color: to set the font color of the SN by clicking the color editor.
- Font Size: to set the font size of the SN by entering a value or clicking .
- Font Width: to set the font width of the SN.
Data
For details about how to configure component data, see Configuring Component Data.
Interaction
For details about whether the component supports the interaction function and how to use the interaction function, see Configuring Component Interaction.
Parent topic: Text
