Accounts
You can use an account associated with the admin role to log in to the ServiceComb engine console and create an account or manage a specified account created in the engine based on service requirements.
Operation |
Description |
Creates an account and associates a proper role with the account. Users who use the account have the access and operation permissions on the microservice engine. You can create up to 1000 accounts, including new accounts and the imported IAM account. |
Imports an IAM account and associates roles with it. Users who use this IAM account have the access and operation permissions on the microservice engine. If the imported IAM account needs to connect microservice applications to the engine through programming interface authentication, reset its password and then use the new password to configure security authentication parameters. When you use this IAM account to log in to the CSE console with security authentication enabled, you do not need to enter the account and password. CSE can manage up to 1000 accounts, including new accounts and the imported IAM account. |
Displays the permissions of the role associated with a specified account. |
Adds or deletes roles for an account. The root account cannot be edited. |
Changes the password of an account that has logged in to the ServiceComb engine based on service requirements or security regulations.
Based on service requirements or security regulations, you can use the account that has logged in to the ServiceComb engine to reset the passwords of other accounts under the engine.
Deletes an account that is no longer used. The root account cannot be deleted. If the account and password are used to register a service in the SDK, deleting the account will affect the service running (the service cannot be registered with the engine). As a result, the service system will be damaged. Exercise caution when performing this operation. |
Adding an Account
Before adding an account, you can create a role based on service requirements. For details, see Creating a Role.
- Click the target ServiceComb engine with security authentication enabled.
- Choose System Management. In the displayed Security Authentication dialog box, enter the name and password of the account associated with the admin role under the ServiceComb engine, and click OK.
If you connect to the ServiceComb engine for the first time, enter the account name root and the password entered when Creating a ServiceComb Engine.
- Choose Accounts > Create Account and configure account parameters by referring to the following table:
Account
Enter an account name.
The account name cannot be changed once the account is created.
Role
Select a role based on service requirements.
An account can be associated with up to five roles.
Password
Enter the password.
Confirm Password
Enter the password again.
- Click OK.
Importing an IAM Account
Before importing an IAM account, you can create a role based on service requirements. For details, see Creating a Role.
- If you connect to the ServiceComb engine for the first time, enter the account name root and the password entered when Creating a ServiceComb Engine.
- For details about how to create an account, see Adding an Account.
- Choose Accounts > Import IAM User Name.
- Select the IAM account to be imported and select account roles. An account can be associated with up to five roles.
- Click Confirm.
The imported account cannot be used for login using a password. If you want to use the imported IAM account to connect microservice applications to the engine through programming interface authentication, Resetting a Password first.
Viewing Role Permissions
- Click the role in the Role column of the account to be viewed in the account list. On the displayed page, view the role and permission configuration associated with the account.
Editing an Account
- On the Accounts tab page, click Edit Account in the Operation column of the account to be edited.
- Select a role based on service requirements. An account can be associated with up to five roles.
- Click Save.
Changing the Password
- In the displayed Security Authentication dialog box, enter the account name and password, and click OK.
- On the Accounts tab, select the account for logging in to the ServiceComb engine and click Reset Own Password in the Operation column.
- Enter the old password and a new password, and confirm the password.
- After confirming that the password needs to be changed, select I Understand.
You can also click Reset Own Password in the upper right corner of the System Management page to change the password of the current login account.
- Click Save.
- On the Accounts tab page, select the account whose password is to be reset, and click Reset Password in the Operation column.
- Enter a new password and confirm the password.
- After confirming that the password needs to be reset, select I Understand.
- Click Save.
Deleting an Account
- On the Accounts tab page, click Delete in the Operation column of the account to be deleted.
- In the displayed dialog box, enter DELETE and click OK.
