Overview
If an application is developed using the microservice framework, the microservice is automatically registered with the corresponding ServiceComb engine after the application is managed and started. You can perform service governance on the engine console by referring to Governing Microservices.
![](https://support.huaweicloud.com/intl/en-us/usermanual-cse/public_sys-resources/note_3.0-en-us.png)
This function is supported by ServiceComb engine 1.x and 2.4.0 and later versions.
