更新时间:2021-09-18 GMT+08:00
配置文件
当前提供的算子开发界面,功能尚未完善。高阶功能,需要通过编辑配置文件“custom.template.json”实现。
配置文件“custom/config/custom.template.json”的结构,如下所示:
{ "i18n": { "zh": { "learnware_fcn_data_preprocessing": "数据预处理", }, "en": { "learnware_fcn_data_preprocessing": "Data Pre-processing" } }, "operators": [ { "id": "learnware_fcn", "icon": "/static/lab/725116af93f13fcc267001ad4c7d3ff3.png", "label": "多层嵌套异常检测学件", "items": [ { "id": "learnware_fcn_data_pre_processing", "icon": "/static/lab/817c016c3910de58e07659426bf40f4d.png", "label": "${i18n.learnware_fcn_data_preprocessing}", "actions": { "id": "learnware-fcn:data_preprocessing", "type": "learnware_fcn_data_pre_processing", "items": [ { "type": 0, "content": "## ${i18n.learnware_fcn_data_preprocessing}" }, { "type": 1, "content": "from naie.learnware.fcn.preprocess import trans_data\ncol_value = 'value' #@param {\"type\":\"string\",\"label\":\"指标列\"}\ncol_label = 'is_anomaly' #@param {\"type\":\"string\",\"label\":\"标签列\"}\nmode = 'train'#@param {\"type\":\"string\",\"label\":\"数据处理模式\",\"radios\":[{\"text\":\"训练\",\"value\":\"train\"},{\"text\":\"测试\",\"value\":\"test\"}]}\ntrain_data = trans_data(datareference,col_value='value',col_label='is_anomaly',mode=mode)" } ] } } ] } ], "formConfig": [], "recommendations": { "learnware_fcn_data_pre_processing": [ "learnware_fcn_model_training", "learnware_fcn_model_test" ] }, "restrictions": { "operators": ["learnware-init", "learnware_fcn_data_pre_processing"], "restrictions": [{ "id": "learnware-init", "first": true, "maxInstanceNum": 1 }] } }
图片暂时不支持动态注册,算子的图标目前只能从平台预置图标中选择。
参数说明如下所示:
父主题: 自定义学件开发指南
