Features
Table 1 describes the commonly used features of COC.
Feature |
Description |
Region Availability |
Overview |
The following feature modules are available on the COC overview page: resource overview, resource monitoring, application monitoring, security overview, quick entries, and more. You can view and perform operations on work items with ease on the overview page, enjoying simplified and highly efficient O&M. |
Global |
Resource management |
COC provides a resource management view that is bolstered by management capabilities for various resources. By using this feature, you can create resource topologies, aggregate resources by resource type, query resources from the resource list by resource tag, and install the UniAgent components. |
Global |
Application management |
COC provides an application-centric resource management view that is bolstered by the capability of modeling the association between applications and resources. By using this feature, you can manage your resources by application, region, resource group, or resource model, query resources in a resource list by tag, and install the UniAgent components. |
Global |
Patch management |
You can manage patches on ECS instances, scan OS compliance, and repair OSs whose patches are non-compliant. |
Global |
Batch operations on ECSs |
You can batch manage ECSs, including batch starting, stopping, and restarting ECSs, and switching and reinstalling OSs for ECSs. |
Global |
Batch operations on RDS instances |
You can batch manage RDS DB instances, including starting, stopping, and restarting RDS DB instances in batches. |
Global |
Batch operations on FlexusL instances |
You can manage FlexusL instances, including starting, stopping, and restarting instances, and reinstalling OSs in batches. |
Global |
Script management |
You can create, modify, and delete scripts, and execute your own and public scripts on VMs (Script management is only allowed on ECSs currently.) |
Global |
Job management |
You can create, modify, and delete jobs, and execute jobs on VMs (Job management is only allowed on ECSs currently.) |
Global |
Scheduled O&M |
You can either select job or script execution tasks from existing tasks or create such tasks. There are two task execution methods available: one-time execution and periodic execution. Periodic task execution includes execution using Cron expressions and simple periodic execution. |
Global |
Parameter center |
You can manage parameters throughout the whole service lifecycle in regions to continuously monitor parameter correctness and consistency. You can quickly reference O&M scenarios such as job orchestration. |
Global |
Incident center |
You can check all incidents on the incident dashboard in the COC incident center. You can also manually handle incidents, associate incidents with jobs, escalate or deescalate incidents, forward incidents to their owners, check handling records of incidents, and initiate WarRoom requests with several clicks. |
Global |
Alarm center |
You can clean original alarms based on alarm forwarding rules and then create alarms. Alarms can be allocated to O&M engineer shifts or individuals so that alarm owners are clear. You can manually clear alarms, convert alarms to incident tickets, or use the automated alarm handling feature. |
Global |
Warrooms |
WarRoom requests can be initiated manually or automatically, and O&M groups for handling WarRoom requests can be quickly created based on the WarRoom initiating rules. Backed by the following features or platforms, this feature delivers powerful O&M capabilities: WarRoom management platform, key monitoring data dashboard, key change operations, and the fault recovery operation platform. In addition, linkage between internal and external WarRoom requests is enabled to ensure quick issue resolving. |
Global |
Forwarding rules |
Forwarding rules suppress, reduce noise, deduplicate, and distribute routes for all received original alarms. Vertical suppression and horizontal convergence of multiple monitoring sources are supported for multi-dimensional noise reduction. When configuring an incident forwarding rule, you can specify default objects for assigning incidents and configure notification policy for precise accurate notification. |
Global |
Data source integration |
You can quickly integrate with existing or external monitoring systems with ease for centralized alarm management. Each monitoring system employs distinct integration access keys for seamless interconnectivity. |
Global |
Change management |
The change center provides a unified platform for engineers to manage change tasks. With the change center, engineers can submit tickets to manage change requests, review, and execution. |
Global |
Chaos drills |
You can configure fault drill templates and attack templates and perform fault drills on physical machines, VMs, or Cloud Container Engine (CCE) containers using the templates. You can also manage failure modes. |
Global |
To-do center |
On the to-do task dashboard, you can view the handling status of to-do tasks, historical to-do task statistics, and overview of all to-do tasks. You can also manually create to-do tasks. |
Global |
Execution records |
On the execution record page, you can query service ticket records of operations on patches, scripts, jobs, and ECSs, and view service ticket details. |
Global |
O&M engineer management |
You can centrally manage O&M engineers on COC using this feature. You can manage users of the current tenant on the O&M Engineer Management page. The basic user data on the O&M Engineer Management page is synchronized from Identity and Access Management (IAM) and is used by multiple basic functional modules in creating to-do tasks, performing scheduled O&M, managing notifications, managing incidents, and more. |
Global |
Schedule management |
You can manage O&M engineers centrally, from multiple dimensions, in different forms, or based on your other custom requirements. You can also create shift scheduling scenarios and roles and add members to the scenarios and roles as required. |
Global |
Notification management |
The notification management module allows you to create notification subscription instances that contain notification scenarios and matching rules. When a change ticket is generated, the notification module first matches the ticket with notification rules and scenarios, then parses the O&M engineers to be notified, the notification content, and notification method, and finally sends the notification messages. |
Global |
Mobile application management |
You can bind or modify mobile apps. (Currently, only WeCom is supported.) |
Global |
SLA management |
Service Level Agreement (SLA) provides ticket timeliness management for you. When a ticket triggers a rule, the SLA notifies you to follow up and handle the ticket in a timely manner, and it records details about the ticket SLA triggering. In SLA management, you can use public SLA rules or user-defined rules, and can configure notifications for SLA violation and warning. |
Global |
Account management |
Allows you to manage and host ECS accounts and periodically change passwords of ECS accounts. |
Global |
