Help Center/ Cloud Operations Center/ User Guide/ Fault Management/ Alarms/ Creating an Alarm Conversion Rule
Updated on 2026-09-21 GMT+08:00
Enterprise IT architectures are becoming increasingly complex, and alarm data from multiple monitoring systems such as servers, network devices, and cloud services is in different formats and standards. These raw alarms directly go to the O&M process, which often floods systems with unnecessary data while burying key issues. Furthermore, such data leads to inconsistent fault handling standards, lowering fault response and team collaboration efficiency.
In the standard O&M system, COC, various types of raw alarms are converted to those that can be handled in a unified process. This ensures accurate notification and quick response. In addition, response plans can be configured to implement automatic fault recovery. To this end, alarm conversion rules are used for the standard process to handle alarms from different monitoring systems. This improves O&M efficiency with automation.
What Is an Alarm Conversion Rule?
Alarm conversion rules process all ingested raw integrated alarms by performing suppression, noise reduction, deduplication, and routing. They support vertical suppression and horizontal convergence across multiple monitoring sources to achieve multi-dimensional noise reduction.
These rules can aggregate one or more disparate raw alarms into a single aggregated alarm. Conversely, a single raw alarm can also trigger multiple conversion rules simultaneously. For details about the configuration items of alarm conversion rules, see Table 2.
  • Before configuring an alarm conversion rule, ensure that the monitoring system for which the alarm conversion rule you want to configure has been connected in the Data Sources module.
  • You have enabled the fault management package. For details about billing, see Billing Items.
  • Once an alarm conversion rule generates an incident, no new incidents will be created by that same rule if its conditions are met again, provided the existing incident has not yet reached the Completed or Closed status. This suppression mechanism is enabled by default but can be disabled.
  • If you receive no raw alarms within the corresponding time window for generating aggregated alarms using alarm conversion rules, the system considers the alarms generated in the previous window period as historical alarms (that is, the current alarm status is set to Handled by default).
  1. Log in to COC.
  2. In the navigation pane, choose Fault Management > Alarm Forwarding Rules.
  3. On the page that is displayed, click Create in the upper right corner. The page for creating an alarm conversion rule is displayed.
  4. On the page, set basic information about the alarm conversion rule by referring to Table 1.
    Table 1 Basic information parameters
    Rule
    Specify the name of the alarm conversion rule you want to create.
    Region
    (Optional) Select a region.
    If no region is selected, default is displayed, indicating that no region is required.
    Enterprise Project
    Select an enterprise project.
    Application
    Select an application.
  5. On the page, set trigger conditions for the alarm conversion rule by referring to Table 2.
    Table 2 Parameters for configuring a trigger rule
    Trigger Type
    The options are Incident and Alarm.
    • Incident: An incident ticket is generated. The on-duty personnel need to handle the incident ticket as soon as possible and continuously trace the incident ticket until it is closed.
    • Alarm: Alarms are generated and are manually or automatically closed based on response plans.
    Data Source
    Select a data source.
    A data source is the system where raw alarms are from.
    Before configuring a trigger rule, ensure that data source has been integrated and enabled. When all conditions are met, the alarm conversion rule is triggered. For details about how to set the data source, see Integrating a Monitoring System.
    Trigger Conditions
    Select the key, comparison method, and value for the trigger conditions.
    A maximum of five trigger conditions can be added. For details about how to set the keys, see Table 3.
    Trigger Rule
    Select a trigger rule.
    Incident Level
    This parameter is required only when Trigger Type is set to Incident. The options are P1, P2, P3, P4, and P5.
    P1 incidents are the most critical, while P5 incidents are the least severe.
    Silence Rule
    This parameter is required only when Trigger Type is set to Incident. Enable or disable this rule as required.
    After an incident is generated based on the alarm conversion rule, a new incident ticket will not be generated if the trigger rule is met before the incident ticket is completed or closed.
    Alarm Severity
    This parameter is required only when Trigger Type is set to Alarm. The value can be Critical, Major, Minor, or Warning.
    Table 3 Parameters for trigger conditions
    Alarm Field from Cloud Eye
    Alarm Field from AOM
    alarmId
    Alarm ID
    alarm_id
    id
    alarmName
    Alarm name
    alarm_name
    event_name in the metadata
    alarmLevel
    Alarm severity. The options are Critical, Major, Minor, and Warning.
    AlarmLevel
    event_severity
    time
    Time when an alarm is generated
    time
    starts_at
    nameSpace
    Service namespace
    namespace
    namespace
    region
    Region
    Region in template_variable
    application
    Application name
    resourceName
    Resource name
    ResourceName in template_variable
    resource_id in the metadata
    resourceId
    Resource ID
    ResourceId in template_variable
    alarmDesc
    Alarm description
    AlarmDesc in template_variable
    URL
    Raw alarm URL
    Link in template_variable
    alarmStatus
    Alarm status. The value can be alarm (active alarm) or ok (alarm handled).
    alarm_status
    alarmSource
    Alarm data source. For example, if an alarm is reported from Cloud Eye, the value is Cloud Eye.
    additional
    Additional alarm information. Format: additional.xxx.
    Except the preceding parameters, other parameters are contained in this parameter and are represented by additional.xxx. For more information about parameters on Cloud Eye, click here.
    Except the preceding parameters, other parameters are contained in this parameter and are represented by additional.xxx. For more information about parameters on AOM, click here.
    recTime
    Time when COC receives an alarm. The value is a 13-digit timestamp.
  6. Set the response plan to be executed after the alarm conversion rule is triggered. For details, see Table 4.
    Table 4 Response plan parameters
    Task Type
    The options are Contingency plan, Script, and Job.
    Automatic Execution
    Determine whether to automatically execute what you have selected. Automatic contingency plans, scripts, and jobs can be automatically executed.
    • If you select Automatic Execution, Parameter Mapping will be displayed. The system automatically executes tasks based on the trigger conditions and settings.
      The parameter value, region ID, and target instance must be in the format of ${}. You need to use this expression to parse the corresponding value. For details, see Examples of Automatic Execution Parameters.
    • If you deselect Automatic Execution, you can click the link on the left to manually execute the task.
  7. Set the owner to whom the alarm or incident is assigned after the conversion.
    Table 5 Parameters for configuring a dispatch rule
    Owner
    Select Shift or Individual.
    • Shift: Select a shift scenario and corresponding roles from the drop-down lists based on the configured values. For details about how to configure a shift, see Shift Schedule Management.
    • Individual: Select an owner. For details about how to configure an owner, see Personnel Management.
  8. Click OK.
    After the rule is created, you can view the created rule in the alarm conversion rule list. After rules are configured for integrated data sources, any reported raw alarm will be automatically converted to an aggregated alarm or an incident that can be automatically handled.
Example:
Alarm data:
"alarmId": "al1696664837170EWbvx24kW",
"alarmName": "alarm-4z39coctest1007",
"URL": "https://console.***.com/ces/?region=***#/alarms/detail?alarmId=al16849986549022X5Vp4pxr",
"additional": {
"dimension": "instance_id:29d99a09-2d15-4ced-8723-6e94ae1c1472",
  • To obtain the value of alarmId in the current alarm data, use the following expression:
    ${currentAlarm.alarmId}
  • To obtain the UUID of instance_id from the additional.dimension string, use the following expression:
    ${string.substring(currentAlarm.additional.dimension, string.indexOf(currentAlarm.additional.dimension, 'instance_id:') + 12)}
    Alternatively, use the following expression:
    ${string.substring(currentAlarm.additional.dimension, 12)}
  • To obtain the region ID of cn-north-7 from the URL string, use the following expression:
    ${string.substring(currentAlarm.URL, string.indexOf(currentAlarm.URL, 'region=') + 7, string.indexOf(currentAlarm.URL, '#/alarms'))}
    In the expression, currentAlarm. is a fixed prefix, which indicates that the data is obtained from the existing alarm data.
More Operations
After an alarm conversion rule is created, you can disable, enable, modify, copy, or delete the rule.
Table 6 More operations
Function
Disabling an Alarm Conversion Rule
Once the rule is disabled, newly collected raw alarms will not trigger the rule.
  1. In the alarm conversion rule list, locate the target rule and click Disable in the Operation column.
  2. In the displayed dialog box, click OK. The alarm conversion rule is disabled.
Enabling an Alarm Conversion Rule
After the rule is enabled, newly collected raw alarms will trigger the rule.
  1. In the alarm conversion rule list, locate the target rule and click Enable in the Operation column.
  2. In the displayed dialog box, click OK. The alarm conversion rule is enabled.
Modifying an Alarm Conversion Rule
After an alarm conversion rule is created, you can modify it based on service changes.
  1. In the alarm conversion rule list, locate the target rule and choose More > Modify in the Operation column.
  2. Modify parameters based on service changes. For details about the parameters, see Creating an Alarm Conversion Rule.
  3. After the setting is complete, click OK. The alarm conversion rule is modified.
Copying an Alarm Conversion Rule
You can copy a rule to quickly create a rule that adapts to new service requirements. This greatly saves time in new rule configuration.
  1. In the alarm conversion rule list, locate the target rule and click Copy in the Operation column.
  2. (Optional) Adjust parameter configurations as required. For details about the parameters, see Creating an Alarm Conversion Rule.
  3. Click OK. The alarm conversion rule is copied.
Deleting an Alarm Conversion Rule
If an alarm conversion rule is no longer needed, you can delete it.
Deleted rules cannot be restored. Exercise caution when performing this operation.
  1. In the alarm conversion rule list, locate the target rule and choose More > Delete in the Operation column.
  2. In the displayed dialog box, click OK. The alarm conversion rule is deleted.
