Help Center/ Cloud Operations Center/ User Guide/ Fault Management/ Incidents/ Handling an Incident Ticket Through a War Room
Updated on 2026-10-28 GMT+08:00
When massive faults or major faults occur, a war room can be initiated to include O&M, R&D, and operation personnel for quick service recovery. You can add related members to the war room for fault rectification. The notification of fault rectification progress is sent to the personnel who are concerned about the fault in a timely manner. The application diagnosis and response plans can help quickly recover applications.
A war room can be initiated only for incidents that are being processed. For details, see Initiating a War Room.
Precautions
If a group (WeCom or DingTalk group) needs to be set up when a war room is initiated, configure the following information:
Figure 1 War room handling process
The war room handling process is as follows:
1. If the existing war room initiation rules do not meet the current scenario, create one by referring to Creating a War Room Initiation Rule. The corresponding rule can be matched based on the preset region, application, and incident level.
2. If an incident meets a war room initiation rule, initiate a war room on the Incidents > Handle Incident page by referring to Initiating a War Room.
3. Analyze the fault impact scope and recover all affected applications.
If other applications are affected, add affected applications by referring to Adding an Affected Application.
4. Locate the root cause of the fault using application diagnosis and rectify the fault by executing response plans. After the fault is rectified, change the application status to Restored.
5. Check the fault handling result and application status and set fault information by referring to Modifying Fault Information.
Note: The fault can be rectified only after all applications associated with the war room are recovered.
6. Close the war room after the fault is rectified.
Note: The war room can be closed only after all mandatory parameters in Modifying Fault Information are set.
  • If some product, O&M, or management items need to be improved during fault handling, you can create improvement tickets and handle them through improvement management.
More Operations
You can also perform the following operations.
Table 11 More operations
Function
Operation
Modifying a war room initiation rule
You can modify a created war room initiation rule.
  1. Choose Fault Management > WarRoom > WarRoom Rules. On the displayed page, locate the target war room initiation rule and click Modify in the Operation column.
  2. Modify the war room initiation rule based on the service scenario.
  3. Click OK.
Deleting a war room initiation rule
If a created war room initiation rule is no longer needed, you can delete it.
Note: Deleted rules cannot be restored. Exercise caution when performing this operation.
  1. Choose Fault Management > WarRoom > WarRoom Rules. On the displayed page, locate the target war room initiation rule and click Delete in the Operation column.
  2. In the displayed dialog box, click OK.
Helpful Links
On COC, you can create and query war rooms by calling APIs. For details, see War Rooms.
