Overview
A job is a collection of operations (atomic actions). A job can contain one or more operations, such as restarting ECSs and executing scripts.
Jobs are classified into public jobs and custom jobs. To help you quickly use COC automated O&M, COC provides public jobs. You can also create custom jobs based on your O&M scenarios to improve flexibility.
- Public jobs: Public jobs are solutions for several common O&M scenarios. Job details are visible to all users. However, users are not allowed to add, modify, and delete public jobs.
- Custom jobs: Custom jobs are created and managed by users. They include custom scripts, APIs, and process control. You can set global parameters for custom jobs, which can be customized or associated with the parameter center.
You can create, modify, clone, and delete public and custom jobs, and execute defined jobs on target instances. You can execute preset operation processes in batches and standardize them on target instances. Up to 100 job versions can be managed, meeting version iteration and backtracking requirements.
Core Functional Modules
| Feature | Description |
| Review configurations: When creating or modifying a job, you can forcibly specify a shift or an individual user as the reviewer. | |
| You can execute custom jobs of the current tenant and change job versions. | |
| After a job is executed, a service ticket record is generated to record the job execution result. |
