Setting Review Configurations
When creating or modifying a job, you can forcibly specify a shift or individual user as a reviewer and notify the reviewer through SMS messages or DingTalk. The reviewer needs to review the created or modified job.
Precautions
If you want to configure a reviewer by specifying a shift, you need to create a shift in Overview in advance.
If Manual Review was enabled, you can select a risk level for jobs. If you select the same risk level when creating a custom job, it means this job needs to be reviewed and the Manual Review parameter will be forcibly enabled.
Setting a Review Configuration
- Log in to COC.
- In the navigation pane on the left, choose Resource O&M > Automated O&M.
- In the Routine O&M area, click Job Management.
- In the Custom Jobs tab page, click Review Configurations.
- Set parameters on the displayed page.
Table 1 Parameters of review configurations Parameter
Manual Review
Disabled by default. If this parameter is disabled, you do not need to set other parameters on this page. If this parameter is enabled, the parameter configuration for creating a custom job is affected.
If this parameter was enabled, you can select a risk level for jobs. If you select the same risk level when creating a job, it means this job needs to be reviewed and this parameter will be forcibly enabled.
Risk Level
The value can be High, Medium, or Low.
If you select the same risk level when creating a custom job, it means this job needs to be reviewed and the enterprise project, reviewer, and notification mode will be automatically configured to the values you set in this page.
Enterprise Project
Select an enterprise project from the drop-down list.
Reviewer
Select Shift or Individual.- Shift: Select a scenario and role from the drop-down lists based on the configured values. For details about how to configure a shift, see Shift Schedule Management.
- Individual: Select a reviewer. For details about how to configure a reviewer, see O&M Engineer Management.
Notification Mode
Select a value from the drop-down list.
- Default: Same as that selected in the reviewer subscription function. For details about how to set the default notification mode, see Selecting a Notification Method.
- SMS, WeCom, DingTalk, Phone, Lark, and Email: Notifications are sent based on the information reserved by the reviewer. For details about how to set reviewer information, see Modifying Personnel Information.
- No notification: The system does not notify any recipient.
- Click OK.
The review configuration is complete.
