Updated on 2026-11-24 GMT+08:00
Notification Management
Notification Management provides users with preconfigured message templates for changes, incidents, issues, alarms, and other operational events. It supports a variety of notification channels to meet diverse communication needs across different business scenarios and workflow stages. It also supports on-demand subscription to notifications, helping users avoid information overload while ensuring critical data is not missed.
When an incident ticket, issue ticket, alarm ticket, or change ticket is generated, the corresponding notification rules match the information about the incident, issue, alarm, or change. Then, the system determines the appropriate recipients, message content, and delivery channels, and sends out notifications accordingly—enabling fully automated alerting and communication. There are notifications for incident tickets, issue tickets, change tickets, and alarm tickets.
The system provides multiple built-in message templates for the preceding O&M service tickets. You can select a template based on your scenario.
Precautions
  • In shift scenarios, notifications are deduplicated by person, not by mobile number. Therefore, individuals who share the same mobile number receive duplicate notifications. The same behavior applies to individual scenarios.
  • When an incident ticket or a change ticket triggers multiple notifications, and the recipients or other subscription criteria of those notifications are identical, the notification module deduplicates the message recipients. As a result, each recipient receives only one SMS notification in the same context, rather than multiple identical messages.
  • When no value is set for a rule, that rule is bypassed during matching.
    For example, if rule A has no value set, it is not evaluated, and the notification instance may still take effect provided all other applicable rules are satisfied. Furthermore, even if the definition of rule A is later modified (e.g., its name or logic type), as long as its value remains unset, the notification instance continues to take effect without evaluating rule A.
Creating a Notification
Create a notification rule. After an incident, issue, or change ticket matches the corresponding rule, a notification is automatically sent.
  1. Log in to COC.
  2. In the navigation pane, choose Basic Configurations > Notification Management.
  3. Click Create Notification.
  4. Set the notification rules by referring to Table 1.
    Table 1 Parameters for creating notifications
    Name
    Specify a notification name.
    The notification name can contain only letters, digits, hyphens (-), and underscores (_).
    Type
    The options are Incident notification, Issue notification, Change notification, and Alarm notification.
    Template
    Select one or more notification templates.
    Notification template content is preset on COC. The template list varies depending on the notification type. After a template is selected, the notification template details are displayed.
    Notification Scope
    Select one or more notification scopes by application.
    If you select an application and the incident ticket contains the application, the subscription takes effect and notifications are sent based on the subscription without considering other matching rules.
    Recipient
    The options are Ticket owner, Ticket creator, Shift, Individual, and Group. Multiple options can be selected at a time.
    Set the objects to be notified and send notifications to the corresponding recipients.
    • Ticket creator: This parameter is not required for alarm notification.
    • Shift: Select a shift scenario and corresponding roles from the drop-down lists based on the configured values. For details about how to configure a shift, see Shift Schedule Management.
    • Individual: Select an individual that you want to notify. For details about how to configure a recipient, see Personnel Management
    • Group: Select a group you want to send notifications to and specify target group members as the recipients. You can also specify the service ticket owner as the recipient. If you do not specify the service ticket owner or other group members as the recipients, all of them in the group will be notified by default. For details about how to configure a group, see Personnel Management
    Level
    (Optional) Select one or more notification levels.
    Type
    (Optional) Select one or more notification types.
    This parameter is not required if you need to notify users of an alarm.
    Source
    (Optional) Select one or more notification ticket sources.
    Region
    (Optional) Select one or more notification ticket regions.
    Method
    You can select All, SMS, WeCom, DingTalk, or Email. Multiple options can be selected.
    Before setting this parameter, configure WeCom or DingTalk by referring to Mobile App Management.
  5. Click OK.
    After a notification is created, it is enabled by default. A notification is sent when the corresponding service ticket matches the notification rule.
    For example, if the notification type is set to incident, the notification template is set to incident creation, and the source is set to alarm, a notification is sent when an alarm is converted to an incident.
Enabling or Disabling a Notification
  1. Log in to COC.
  3. Locate the notification you want to enable or disable and click Enable or Disable in the Operation column.
  4. Click OK.
    There are two types of notification statuses:
    • Green: indicates that the notification is effective.
    • Red: indicates that the notification is invalid.
Modifying a Notification
Modify existing notification information.
  1. Log in to COC.
  3. Locate the target notification and click Modify in the Operation column.
    The parameters are similar to those for creating a notification.
  4. After the setting is complete, click OK.
Deleting a Notification
  1. Log in to COC.
  3. Locate the notification you want to delete and click Delete in the Operation column.
  4. Click OK.
    After the notification rule is deleted, it is no longer displayed in the notification list, and no notification will be sent for the corresponding scenario.
Helpful Links
If a notification rule is triggered for an alarm, incident, issue, or change ticket, a notification is automatically sent. For related operations, click the following links.
