Updated on 2026-10-28 GMT+08:00
Creating an Incident Ticket
COC provides multiple methods to generate incident tickets to record faults. Incident tickets can be generated by converting aggregated alarms or directly from raw alarms. If these two methods cannot meet your service requirements, you can manually create incident tickets.
Precautions
Confirm the content of the incident ticket and fill in the incident level.
  1. Log in to COC.
  2. In the navigation pane, choose Fault Management > Incidents.
  3. On the Incidents page, click Create in the upper right corner. The page for creating an incident ticket is displayed.
  4. On the page for creating an incident ticket, set the incident ticket information.
    Figure 1 Incident ticket details
    Figure 2 Basic information
    Table 1 Parameters for creating an incident ticket
    Incident
    Enter a custom incident name.
    Describe the incident.
    Click Add File to upload incident-related attachments.
    A maximum of 10 files can be uploaded. The supported file types are JPG, PNG, DOCX, TXT, and PDF. The size of a single file cannot exceed 10 MB.
    Incident Level
    The options are P1, P2, P3, P4, and P5.
    Default incident levels:
    P1: Core service functions are unavailable, affecting all customers.
    P2: Core service functions are affected, affecting the core services of some customers.
    P3: An error is reported for non-core service functions, affecting some customer services.
    P4: Non-core service functions are faulty. The service latency increases, the performance deteriorates, and user experience decreases.
    P5: Non-core service exception occurs, which is customer consultation or request issue.
    Incident Ownership
    (Optional) Select the incident to which the ticket belongs.
    • Alarm detection
    • Customer fault reporting
    • Proactive O&M
    • Other
    Incident Type
    (Optional) Select an incident type.
    Region
    (Optional) The preset value is N/A. Select the region where the incident occurs.
    Enterprise Project
    Select an enterprise project.
    Fault Occurrence Time
    Enter the time when the fault occurs.
    Application
    Select the application affected by the incident.
    Service Interrupted
    The options are Yes and No.
    Owner
    Select Shift or Individual.
    • Shift: Select a shift scenario and corresponding roles from the drop-down lists based on the configured values. For details about how to configure a shift, see Shift Schedule Management.
    • Individual: Select an owner. For details about how to configure an owner, see Personnel Management.
  5. Click OK.
    After the incident ticket is created, you can view the status of the ticket in the incident ticket list and process the incident ticket.
Helpful Links
