What's New
The tables below describe the functions released in each Cloud Container Engine version and corresponding documentation updates. New features will be successively launched in each region.
March 2026
| No. | Feature | Description | Phase | Document |
| 1 | Kubernetes 1.34 clusters are in commercial use. | CCE allows you to create Kubernetes 1.34 clusters. | Commercial use | |
| 2 | The minimum system disk size for a node is 20 GiB. | During CCE node or node pool creation, the system disk can be configured as small as 20 GiB. | Commercial use | |
| 3 | LoadBalancer Services and ingresses support HTTPS health checks. | HTTPS health checks can now be configured for LoadBalancer Services and ingresses. | Commercial use |
December 2025
| 1 | CCE supports node-scoped ServiceAccount permissions. | ServiceAccount tokens are restricted to cluster resources on the pod's host node. | Commercial use | |
| 2 | CCE cluster certificates can be manually rotated before they expire. | CCE provides certificate rotation. You can manually trigger a certificate rotation via the console or API prior to expiration. CCE sends expiration notifications six months in advance, displays a certificate expiration alert in the console, and delivers notifications through the Message Center. | Commercial use | |
| 3 | Kubernetes 1.34 clusters are in OBT. | CCE allows you to create Kubernetes 1.34 clusters. | Open beta testing | |
| 4 | CCE supports specifying enterprise projects and TMS tags during dynamic creation of OBS storage volumes. | CCE allows you to specify enterprise projects and TMS tags for OBS buckets during dynamic provisioning. | Commercial use | |
| 5 | DataPlane V2 uses eBPF instead of kube-proxy for CCE v1.34 clusters. | CCE supports Data Plane V2, which uses eBPF to accelerate traffic forwarding for Services and NetworkPolicies. | Commercial use | |
| 6 | DataPlane V2 in CCE clusters supports Ubuntu 22.04. | CCE clusters running DataPlane V2 now support Ubuntu 22.04, extending eBPF-based networking to additional node operating systems. | Commercial use | |
| 7 | CCE supports password-free pulls of SWR private images. | CCE supports password-free container image pulling, eliminating the need for imagePullSecrets by leveraging node-level repository authentication. | Commercial use | |
| 8 | CCE supports ELB traffic mirroring for LoadBalancer ingresses. | The traffic to a specified backend server group is mirrored to the target backend server group for traffic inspection, audit analysis, and troubleshooting. | Commercial use | Configuring an Advanced Forwarding Policy for a LoadBalancer Ingress |
September 2025
| 1 | CCE supports automatic directory creation for SFS and SFS Turbo. | The dynamic subdirectory creation feature of SFS and SFS Turbo enables automatic creation of subdirectories during storage volume configuration. | -- | Creating an SFS Subdirectory Using a Dynamic PV (Recommended) Creating an SFS Turbo Subdirectory Using a Dynamic PV |
| 2 | DataPlane V2 supports the open-source Hubble. | In a cluster with DataPlane V2 enabled, DataPlane V2 allows deployment of the open-source Hubble to visualize container network traffic. | -- | |
| 3 | CCE AI Suite (Ascend NPU) uses npu-exporter to monitor NPU metrics. | CCE AI Suite (Ascend NPU) integrates npu-exporter for NPU monitoring. DCGM-Exporter gathers essential performance data like NPU usage, memory usage, temperature, and power consumption, and makes the data available to monitoring systems like Prometheus. This enables real-time monitoring of NPU performance, helping optimize NPU resource utilization effectively. | -- | |
| 4 | CCE supports the NVIDIA GPU driver of the latest version. | CCE supports the latest NVIDIA GPU driver (570.86.15). | -- | |
| 5 | CCE supports blocklists for custom log collection policies. | Custom log collection policies support blocklists. You can use instance tags to exclude pods that do not require standard container output log collection. | -- | |
| 6 | Kubernetes 1.33 clusters are in OBT. | CCE allows you to create Kubernetes 1.33 clusters. | -- |
July 2025
| 1 | Kubernetes 1.32 clusters are in OBT. | CCE allows you to create Kubernetes 1.32 clusters. | Open beta testing | |
| 2 | CCE allows you to disable service pod scheduling to nodes before the node post-installation scripts complete. | By default, pods may be scheduled to a node while the node post-installation script is still executing. If the script times out, the node installation fails, and the pods may also be impacted. To avoid this, you have the option to set the node as unschedulable before its post-installation script is complete during the node installation. This ensures that pods are only scheduled to nodes where the post-installation scripts have completed, helping prevent service instability caused by incomplete node setup. | Commercial use | |
| 3 | CCE supports DataPlane V2 for newly created CCE clusters that use the VPC networks. After DataPlane V2 is enabled, CCE allows you to configure network policies for these clusters. | You can enable DataPlane V2 for newly created clusters that use the VPC networks. With DataPlane V2 enabled, the clusters can process network traffic more efficiently, and you have the option to use network policies to control network communication between pods. | Commercial use | |
| 4 | CCE supports automatic updates of AK/SK credentials for parallel file systems of OBS. | When parallel file systems of OBS are used, the CCE Container Storage (Everest) add-on supports automatic AK/SK update propagation. After the access keys of an OBS volume are updated, CCE automatically detects the change and applies the new keys to all affected workloads. This eliminates the need to manually restart these workloads, ensuring seamless service continuity during the key update. | Commercial use | Automatically Applying Updated Access Keys (AK/SK) for an OBS Volume |
| 5 | Both LoadBalancer Services and ingresses support rewriting of the X-Real-IP field in HTTP/HTTPS request headers. | LoadBalancer Services and ingresses can rewrite the X-Real-IP field in HTTP/HTTPS request headers using the source IP addresses of clients. This ensures that even if a request passes through multiple proxies or load balancers, the true client IP address is preserved and forwarded to the backend service. | Commercial use | |
| 6 | CCE allows you to configure IP addresses as the ELB backend. | You have the option to configure specific IP addresses as the ELB backend when creating LoadBalancer Services or ingresses. This allows for flexible traffic distribution tailored to different service scenarios. | Commercial use | Configuring IP Addresses as Backend Servers for a LoadBalancer Service Configuring IP Addresses as Backend Servers for a LoadBalancer Ingress |
June 2025
| 1 | Kubernetes 1.31 is now commercially available for CCE. | CCE allows you to create Kubernetes 1.31 clusters. | Commercial use | |
| 2 | Yearly/Monthly nodes added during node pool scale-outs can be automatically paid. | You can configure auto payment during node pool creation. When adding yearly/monthly nodes to the node pools with auto payment enabled, you do not need to pay for the nodes again, simplifying the operations. | Commercial use | |
| 3 | CCE supports automatic assignment of EIPs to newly added nodes in node pools. | When creating a node pool, you can enable automatic EIP assignment for the newly added nodes. This improves efficiency. | Commercial use | |
| 4 | CCE allows you to change the default health check port of the NodeLocal DNSCache add-on. | NodeLocal DNSCache defaults to using port 8080 on the host node, but this can cause conflicts with other services sharing the same port. To avoid conflicts, you can specify an alternative health check port for NodeLocal DNSCache. | Commercial use | |
| 5 | CCE supports custom backend server groups for LoadBalancer ingresses. | LoadBalancer ingresses can forward requests to the backend pods of the associated Services in a CCE cluster and other custom load balancer backend server groups to meet custom service requirements and offer flexible traffic allocation. | Commercial use | Configuring Advanced Forwarding Actions for a LoadBalancer Ingress |
| 6 | CCE supports custom images based on Huawei Cloud EulerOS 2.0 and Ubuntu 22.04. | You can create custom images based on Huawei Cloud EulerOS 2.0 and Ubuntu 22.04. You have more custom options now. | Commercial use |
April 2025
| 1 | Commercial use of CCE Autopilot clusters (Kubernetes 1.31) | CCE Autopilot clusters of Kubernetes 1.31 are commercially available. You can select this version when creating a cluster. | Commercial use | |
| 2 | CCE Secrets Manager for DEW add-on | The CCE Secrets Manager for DEW add-on allows you to mount secrets stored in DEW to service pods. This decouples sensitive information from the cluster environment and prevents sensitive information leak caused by hardcoding or plaintext configuration. | Commercial use |
March 2025
| 1 | Kubernetes 1.31 clusters are in OBT. | CCE allows you to create clusters of Kubernetes 1.31. | Open beta testing | |
| 2 | LoadBalancer ingresses support advanced forwarding actions and return fixed responses. | LoadBalancer ingresses support more advanced forwarding actions, allowing you to perform actions like returning fixed responses or setting rate limits to accommodate a variety of service needs. | Commercial use | Configuring Advanced Forwarding Rules for a LoadBalancer Ingress |
| 3 | CCE Turbo clusters support DataPlane V2 to provide capabilities such as Service network acceleration and network policies. | Once DataPlane V2 is enabled in CCE Turbo clusters, eBPF can be used for traffic forwarding. This enables Service network acceleration and fine-grained network policy management, delivering improved performance and more flexible security policy configurations. It is particularly suited for cloud native scenarios that demand both high performance and robust security. | Open beta testing | |
| 4 | The CCE AI Suite (NVIDIA GPU) add-on supports DCGM-Exporter. | CCE AI Suite (NVIDIA GPU) incorporates DCGM-Exporter to monitor GPU metrics. DCGM-Exporter gathers essential performance data like GPU usage, memory usage, temperature, and power consumption, and makes the data available to monitoring systems like Prometheus. This enables real-time monitoring of GPU performance, helping to optimize GPU resource utilization effectively. | Commercial use | Configuring NVIDIA GPU to Use DCGM-Exporter for GPU Metric Monitoring |
December 2024
| 1 | The default image path of Docker can be customized. | In the management of node pool configuration, you have the option to change the default image path of Docker to other custom image sources. This can greatly enhance the speed and efficiency of image pulling. | Commercial use | |
| 2 | Kubernetes 1.30 is now commercially available in CCE. | CCE allows you to create clusters of Kubernetes 1.30. | Commercial use | |
| 3 | A single system disk can be configured for a node. | CCE allows you to configure a single system disk for each node. There is no need to configure additional data disks for the node. The system disk will be used to store resources such as downloaded images, temporary container storage, and container standard output logs of the node. This method is suitable for scenarios with low resource requirements, and it helps reduce storage costs. | Commercial use | |
| 4 | New subdirectories in dynamically-provisioned SFS Turbo volumes for CCE Autopilot clusters | CCE Autopilot allows you to create subdirectories in PVs that are dynamically provisioned from SFS Turbo file systems when creating PVCs and to configure the capacity of the subdirectories so that different workloads can share the same PVs. | Commercial use | (Recommended) Creating an SFS Turbo Subdirectory Using a Dynamic PV |
| 5 | The node pool password can be changed during the node pool updates. | When updating the configuration of a node pool, you have the option to change the password. It is important to note that this change will only affect new nodes. It will not alter the login configuration of existing nodes in the node pool. | Commercial use | |
| 6 | LoadBalancer ingresses support cross-origin access. | LoadBalancer ingresses support cross-origin resource sharing (CORS), enabling access from different sources. | Commercial use | |
| 7 | Subnets and security groups for namespaces or workloads of CCE Autopilot clusters | You can associate subnets and security groups with different namespaces or workloads for isolation and custom access. | Commercial use | |
| 8 | CCE Autopilot clusters v1.31 | CCE Autopilot allows you to create clusters of Kubernetes 1.31. | Open beta testing | |
| 9 | The Cloud Native Log Collection add-on now offers support for new parameter settings. | Cloud Native Log Collection allows you to configure the initial buffer size, maximum buffer size, and memory buffer limit. | Commercial use |
September 2024
| 1 | CCE Autopilot clusters are in commercial use. | CCE Autopilot allows you to create serverless clusters that offer optimized Kubernetes compatibility and free you from O&M. After a CCE Autopilot cluster is created, you can deploy applications without purchasing nodes or maintaining the deployment, management, and security of nodes. You only need to focus on the implementation of application service logic, which greatly reduces your O&M costs and improves the reliability and scalability of applications. | Commercial use | |
| 2 | CCE enables you to designate directories when you are creating SFS 3.0 file systems using the StorageClass objects. | When creating SFS 3.0 file systems using the StorageClass objects, you can specify directories. | Commercial use | |
| 3 | Expanding the capacity or modifying the specifications of the disk attached to a CCE node does not impact the process of resetting the node. | When you increase the capacity or modify the specifications of a disk attached to a CCE node through the ECS console, the node can be reset on the CCE console. | Commercial use | |
| 4 | CCE allows you to customize the default image path of containerd. | You can customize the default image path of containerd on a node and choose image sources as required. | Commercial use | |
| 5 | Custom node pools in CCE standard or Turbo clusters can accept nodes from the default node pool. | If the node pool constraints are met, you can migrate nodes from the default node pool to an on-premises node pool to fulfill various service needs and enhance resource utilization. | Commercial use | |
| 6 | CCE supports FlexusX. | You are allowed to choose FlexusX when creating nodes in CCE clusters. | Commercial use |
July 2024
| 1 | CCE has optimized the node drainage failure message. | In the event that a node cannot be drained, a clear and detailed error message will be shown. | Commercial use | |
| 2 | CCE offers specific tags for unsubscribed nodes. | By adding a specific tag to a node when unsubscribing, alarm rules can be configured for an on-premises Prometheus platform to prevent false alarms. | Commercial use | |
| 3 | CCE supports the use of existing EIPs for pods in CCE Turbo clusters. | When setting up an EIP for a pod in a CCE Turbo cluster, you have the option to use an existing EIP. | Commercial use | |
| 4 | CCE enables you to cancel node drainage. | You can cancel the node drainage. Once the drainage is canceled, scheduling is restored on the nodes. | Commercial use | |
| 5 | Kubernetes 1.29 is now commercially available in CCE. | CCE allows you to create clusters of Kubernetes 1.29. | Commercial use | |
| 6 | CCE allows you to update node pool agencies. | When updating a node pool, you have the option to adjust the user agency settings associated with the node pool. This allows for more flexible management of access and operation permissions for the node pool. | Commercial use | |
| 7 | CCE has improved the allocation of space for container engines, allowing for the mounting of space to specific paths. | When creating a node, if the total allocated space for the container engine, container images, kubelet, and emptyDir is less than 100%, you can mount the remaining space to a specified path for custom data storage. | Commercial use | |
| 8 | CCE allows you to retain labels and taints when a node is reset. | You have the option to keep or delete specific metadata, including labels and taints, when resetting a node in the default node pool. | Commercial use | |
| 9 | CCE has increased the maximum number of Elastic Volume Service (EVS) disks that can be attached to each node. | The ability to attach disks has been significantly improved, allowing for up to 16 EVS disks to be attached to a single node. | Commercial use | |
| 10 | CCE supports custom header forwarding policies for ingresses. | Dedicated load balancer ingresses support custom header forwarding policies. You can configure different header key-value pairs to determine the backend Service to which data is forwarded. | Commercial use | Configuring a Custom Header Forwarding Policy for a LoadBalancer Ingress |
| 11 | CCE has upgraded node pools, which now offer additional benefits of pay-per-use and yearly/monthly billing modes. | Upgraded node pools provide additional benefits beyond flexible payment options (pay-per-use and yearly/monthly). They also enhance configuration management and improve resource management efficiency and flexibility. | Commercial use | |
| 12 | CCE allows for the replication of default alarm rules. | The default CCE alarm rules can be replicated and modified to fit your needs. | Commercial use |
June 2024
| 1 | CCE supports yearly/monthly or pay-per-use billing mode for EVS disks that are dynamically created. | When dynamically creating EVS disks, you can select yearly/monthly or pay-per-use billing mode for the disks. | Commercial use | |
| 2 | CCE supports multiple types of nodes in yearly/monthly node pools. | Yearly/Monthly node pools support various node types to meet different application scenarios and requirements. | Commercial use | |
| 3 | CCE supports HostAliases for workloads. | During workload creation, you can set up HostAliases, which improve the process of mounting /etc/hosts to containers. | Commercial use | |
| 4 | CCE supports data redundancy policies for OBS volumes that are dynamically created. | When dynamically creating OBS volumes, you can specify a data redundancy policy (single-AZ storage or multi-AZ storage) for the volumes. | Commercial use | |
| 5 | Nodes can be managed in custom node pools. | You can add a newly purchased ECS or a node that has been removed to a node pool in a cluster. | Commercial use | |
| 6 | CCE supports the setting of forwarding rule priorities for ingresses. | When multiple ingresses use the same listener, sorting forwarding rules by priority can make management easier. | Commercial use |
May 2024
| 1 | CCE nodes support General Purpose SSD V2 and Extreme SSD V2 EVS disks. | When creating nodes and node pools, you can select General Purpose SSD V2 or Extreme SSD V2 EVS disks. | Commercial use | |
| 2 | Enterprise projects can be specified when CCE nodes and node pools are created. | When creating a node or node pool, you have the option to choose an enterprise project. The enterprise projects are visible in the node list, making it easier to view costs and manage resources more efficiently. | Commercial use | |
| 3 | CCE supports General Purpose SSD V2 and Extreme SSD V2 Elastic Volume Service (EVS) disks. | CCE supports General Purpose SSD V2 and Extreme SSD V2 EVS disks. The IOPS and throughput can be customized. | Commercial use | |
| 4 | Advanced forwarding policies like URL redirection and rewriting are supported. | CCE LoadBalancer ingresses allow URL redirection and rewriting, as well as HTTP-to-HTTPS redirection. You have the flexibility to configure forwarding policies as needed. | Commercial use | Configuring URL Redirection for a LoadBalancer Ingress |
| 5 | CCE Secrets Manager for DEW (dew-provider) supports credential mounting using secrets. | With CCE Secrets Manager for DEW (dew-provider), you can easily mount credentials stored outside of clusters onto service pods using secrets. | Commercial use | |
| 6 | TLS listeners are supported when Services interconnect with dedicated load balancers. | TLS can be used if ultra-high performance and large-scale TLS offloading are required. You can use TLS to forward encrypted TCP requests from clients for a Service. | Commercial use | |
| 7 | Kubernetes 1.29 clusters are in OBT. | CCE allows you to create clusters of Kubernetes 1.29. | Open beta testing | |
| 8 | CCE adds new common configuration parameters for node pools and clusters. | To make it easier to manage configuration parameters, CCE has added common parameters for in-depth configuration of core components of node pools and clusters. These parameters include the upper and lower limits for image garbage collection and container log files. | Commercial use | |
| 9 | CCE Services and ingresses that use dedicated load balancers provide an option for enabling data compression. | Services or ingresses that use HTTP/HTTPS-compliant dedicated load balancers support data compression. Enabling this feature can reduce the size of files to be transferred, improve file transfer efficiency, and minimize bandwidth usage needed for the transmission. | Commercial use | Configuring GZIP Data Compression for a LoadBalancer Service Configuring GZIP Data Compression for a LoadBalancer Ingress |
April 2024
| 1 | Multiple NGINX ingress controllers can be installed in the same cluster. | You can deploy multiple independent NGINX ingress controllers in a cluster. This allows you to customize each controller to meet specific traffic and security needs. | Commercial use | |
| 2 | NGINX Ingress Controller metrics can be monitored. | CCE allows you to use the Cloud Native Cluster Monitoring add-on to gather metrics on the NGINX Ingress Controller. This allows you to monitor the performance and running status of the NGINX Ingress Controller in real time. | Commercial use | |
| 3 | CCE Autopilot clusters are in OBT. | CCE Autopilot allows you to create serverless clusters that offer optimized Kubernetes compatibility and free you from O&M. After a CCE Autopilot cluster is created, you can deploy applications without purchasing nodes or maintaining the deployment, management, and security of nodes. You only need to focus on the implementation of application service logic, which greatly reduces your O&M costs and improves the reliability and scalability of applications. | Open beta testing | |
| 4 | ELB blocklists or trustlists are supported for access control. | When creating a Service or ingress, you can add IP addresses to a trustlist or blocklist to control access to a listener of a load balancer to improve security. | Commercial use | Configuring a Blocklist/Trustlist Access Policy for a Service Configuring a Blocklist/Trustlist Access Policy for a LoadBalancer Ingress |
| 5 | Kubernetes 1.28 now available in CCE. | CCE allows you to create clusters of Kubernetes 1.28. | Commercial use |
January 2024
| 1 | Ingresses that use dedicated load balancers can interconnect with gRPC backend services. | Ingresses can interconnect with gRPC backend services when dedicated load balancers are used. gRPC is a high-performance general RPC open-source software framework that helps load balancers run over HTTP/2. | Commercial use | Interconnecting LoadBalancer Ingresses with gRPC Backend Services |
| 2 | Multiple subnet CIDR blocks can be configured for a node pool. | When creating a node pool, you have the option to choose multiple subnet CIDR blocks for more flexible allocation of network resources. | Commercial use | |
| 3 | Volcano supports custom workload scale-in priorities. | After the application scaling priority policy is enabled, workload pods can be scaled in or out based on the node priority configured by users. For example, an application pod that runs on a pay-per-use node may be given priority when scaling down. | Commercial use | |
| 4 | Volcano supports load-aware scheduling for nodes. | Volcano Scheduler offers CPU and memory load-aware scheduling for pods and preferentially schedules pods to the node with the lightest load to balance node loads. This prevents an application or node failure due to heavy loads on a single node. | Commercial use | |
| 5 | Kubernetes 1.28 clusters are in OBT. | CCE allows you to create clusters of Kubernetes 1.28. | Open beta testing |
November 2023
| 1 | Kubernetes 1.27 now available in CCE. | CCE allows you to create clusters of Kubernetes 1.27. | Commercial use | |
| 2 | Volcano supports node pool affinity scheduling. | Soft affinity scheduling of a node pool is implemented based on labels in the node pool. Each node in the node pool is scored to select the optimal one for pod scheduling. The rule is to schedule pods to nodes with specified labels as far as possible. | Commercial use | |
| 3 | Volcano supports node load-aware rescheduling. | Volcano scheduler can evict pods that do not comply with the configured policy so that pods can be rescheduled. In this way, the cluster load is balanced and resource fragmentation is minimized. | Commercial use |
September 2023
| 1 | CCE clusters support the dedicated load balancers that use elastic specifications. | Dedicated load balancers are suitable for fluctuating traffic and billed based on the Load Balancer Capacity Units (LCUs) used per hour. | Commercial use | |
| 2 | Kubernetes 1.27 OBT | CCE allows you to create clusters of Kubernetes 1.27. | Open beta testing | |
| 3 | The timeout interval can be configured for a load balancer. | When a LoadBalancer Service or an ELB Ingress is used, the timeout interval can be configured. | Commercial use | |
| 4 | Custom tags can be added to dynamically created EVS disks. | When dynamically creating EVS PVCs, you can add TMS tags to automatically created EVS disks to classify resources. This facilitates cost management. | Commercial use |
June 2023
| 1 | CCE Turbo ENIs support fixed IP addresses. | CCE Turbo clusters support fixed IP addresses for pods (ENIs) of StatefulSets. This is a common practice in access control, service registration, service discovery, and log audit. | Commercial use | |
| 2 | CCE Turbo clusters support CPU Burst to prevent CPU traffic limiting from affecting latency-sensitive services. | If a CPU limit is set for a container in the pod, the CPU usage of the container cannot exceed the limit. Frequent CPU traffic limiting affects service performance and increases the long-tail response latency, especially for latency-sensitive services. CPU Burst is an elastic traffic limiting mechanism that allows temporarily exceeding the CPU limit to reduce the long-tail response time of services. | Commercial use | |
| 3 | Enhances hybrid deployment of CCE Turbo clusters: Pod network priority restriction is supported. | CCE Turbo clusters balance the egress network bandwidth used by online and offline services to ensure sufficient network bandwidth for online services. When the threshold is reached for online services, the bandwidth usage of offline services will be reduced. | Commercial use | |
| 4 | CCE Turbo ENIs support automatic creation and binding of EIPs. | CCE Turbo clusters can automatically bind an EIP to a StatefulSet. This function works with the automated EIP creation function to assign a fixed EIP (fixed public IP address) to each pod. | Commercial use | |
| 5 | Kubernetes 1.25 now available | CCE allows creating clusters of Kubernetes 1.25. | Commercial use | |
| 6 | CCE Turbo clusters support the association between namespaces and container CIDR blocks. | You can set container subnets and security groups by namespace to isolate network. | Commercial use |
November 2022
| 1 | Kubernetes 1.25 OBT | CCE allows creating clusters of Kubernetes 1.25. | Open beta testing | |
| 2 | Huawei Cloud EulerOS 2.0 is supported. | Nodes running Huawei Cloud EulerOS 2.0 can be created in clusters of v1.23 or later. | Commercial use | |
| 3 | Enhanced CPU core binding management policies are supported. | Based on the Kubernetes static policy, the enhanced CPU core binding management policy (enhanced-static) supports burstable pods (whose requests and limits of CPU are positive integers) and allows certain CPUs to prioritize these pods, enhancing application stability. | Commercial use | |
| 4 | CCE clusters support monitoring components of master nodes. | CCE clusters can monitor the kube-apiserver, kube-controller, kube-scheduler and etcd-server components of master nodes. | Commercial use |
July 2022
| 1 | Custom security group for a node pool | You can specify a security group when creating a node pool. | Commercial use | |
| 2 | Enhanced npd add-on | CCE enhances the monitoring on component events, OS, network, and storage, and provides fault isolation. | Commercial use | |
| 3 | Support for containerd | You can select containerd as the container runtime for CCE clusters. | Commercial use | |
| 4 | Workload identity | With workload identities, your workloads in a cluster can access cloud services like IAM users without using the AK/SK, reducing security risks. | Commercial use | |
| 5 | Resource reservation model V2 | For clusters of v1.21.4-r0, v1.23.3-r0, or later, the node memory reservation model is optimized to V2 and can be dynamically adjusted using the node pool parameters kube-reserved-mem and system-reserved-mem. | Commercial use |
April 2022
| 1 | Kubernetes 1.23 now available | CCE supports creating clusters of Kubernetes 1.23. | Open beta testing | |
| 2 | Kubernetes 1.21 now available | CCE supports creating clusters of Kubernetes 1.21. | Commercial use | |
| 3 | Specifying enterprise projects for PVCs | By default, the enterprise project to which a PVC belongs is the same as that to which the cluster belongs. You can now specify an enterprise project. | Commercial use | |
| 4 | CCE Turbo clusters now GA | CCE Turbo clusters run on a cloud native 2.0 infrastructure that features software-hardware synergy to support passthrough networking, high security and reliability, and intelligent scheduling. | Commercial use | |
| 5 | Support for local PVs and ephemeral volumes | Data disks on CCE nodes can be configured as local PVs or ephemeral volumes to provide better data read and write performance. | Commercial use |
December 2021
| 1 | Multiple container CIDR blocks for a CCE cluster | When creating a CCE cluster, you can specify multiple container CIDR blocks. | Commercial use | |
| 2 | Kubernetes 1.21 is now available in CCE. | CCE supports creating clusters of Kubernetes 1.21. | Open beta testing | |
| 3 | Secondary CIDR block for cluster VPC | When creating a cluster, you need to deploy it in a VPC. If the planned VPC is too small and IP addresses are insufficient, you can use a secondary VPC CIDR block to support your service scaling. | Commercial use | |
| 4 | ELB layer-7 forwarding for Services | ELB layer-7 forwarding is available for Services. | Commercial use | |
| 5 | OverlayFS for Docker storage on CCE cluster nodes that run CentOS 7.6 | In CCE clusters of v1.21, the Docker storage mode of CentOS 7.6 nodes is changed from Device Mapper to OverlayFS. | Commercial use | |
| 6 | Interconnection with Cloud Secret Management Service (CSMS) to mount DEW secrets to pods | The dew-provider add-on is connected to CSMS, allowing users to mount secrets stored outside the cluster, that is, the Data Encryption Workshop (DEW) service dedicated to storing sensitive information, to pods for unified secret management. | Commercial use |
June 2021
| 1 | Clusters can be upgraded from Kubernetes 1.15 and 1.17 to 1.19. | CCE supports cluster upgrades from Kubernetes 1.15 and 1.17 to 1.19. | Commercial use | |
| 2 | Released coredns 1.17.7. | coredns 1.17.7 is released, mirroring CoreDNS v1.8.4 in the community upgraded v1.6.5. For details about the changelog, see 1.6.6 to 1.8.4. Note: In the community version 1.7.0, there are changes in CoreDNS metric names. If you collect CoreDNS metric data or configure horizontal CoreDNS scaling policies based on the metrics, pay attention to the metric name changes and update the metric names when using the coredns add-on in CCE. After a version earlier than v1.17.7 is upgraded to v1.17.7, the horizontal CoreDNS scaling policies configured on the System Hardening page need to be deleted and configured on the page again. | Commercial use | |
| 3 | Custom keys are supported for OBS. | everest 1.2.8 and later versions provide the capability of customizing keys. IAM users can use their own keys to mount OBS volumes, by which you can control access permissions to OBS. | Commercial use | |
| 4 | CCE clusters of Kubernetes 1.19.10 can be created. | You can create CCE clusters of Kubernetes 1.19.10. | Commercial use | |
| 5 | ECS/BMS nodes can be managed and removed in batches. | You can accept and remove ECS/BMS nodes from clusters in batches. | Commercial use | |
| 6 | SFS and OBS mount options can be configured. | You can set mount options when mounting SFS and OBS volumes. | Commercial use |
March 2021
| 1 | VM and BMS system disks can be encrypted. | Data disk encryption provides powerful security protection for your data. Snapshots generated from encrypted disks and disks created using these snapshots automatically inherit the encryption function. This function is available only in certain regions. | Commercial use | |
| 2 | Kubernetes 1.19 is now available in CCE. | CCE supports creating CCE clusters of Kubernetes 1.19. | Commercial use | |
| 3 | Ubuntu 18.04 is supported. | You can select Ubuntu 18.04 as the OS when creating a node in a CCE cluster. | Commercial use | |
| 4 | Add-ons compatible with clusters of v1.19 and their new features | Multiple add-ons in the Add-on Marketplace can be used in clusters of Kubernetes 1.19. Certain add-ons are functionally enhanced. | Commercial use | |
| 5 | Node pool configuration management parameters are added for clusters of v1.19. | CCE allows you to limit the number of file handles in a container, enable PodPidsLimit by default and modify it, configure the elastic computing period, and mount the F2FS and OverLayFS file systems to containers. | Commercial use |
October 2020
| 1 | Advanced ELB listener configuration is supported when HTTPS is used to create an ingress. | In scenarios with high network security requirements on clients, users can configure ELB listener settings, for example, selecting security policies. | Commercial use | |
| 2 | Admission Controller for pod security policies | Admission Controller can be enabled for pod security policies in CCE clusters. | Open beta testing |
August 2020
| 1 | Custom metrics are supported for HPA policies. | Custom metrics are supported for HPA policies in clusters of v1.15 and later. You can set custom metric names, metric sources, expected values, and thresholds. | Commercial use | |
| 2 | CCE supports a SNI certificate with multiple domain names of ELB v3. | If multiple domain names are required for external access and different domain names use independent certificates, you need to enable the server name indication (SNI) function. After SNI is enabled, the client is allowed to submit the requested domain name information when initiating an SSL handshake request. | Commercial use |
July 2020
| 1 | Frontend function optimization |
| Commercial use | |
| 2 | CCE supports the mounting of OBS buckets of third-party tenants. | CCE clusters can be mounted with OBS buckets of third-party tenants, including OBS parallel file systems (preferred) and OBS object buckets. Only parallel file systems and object buckets of third-party tenants in the same region can be mounted. | Commercial use | |
| 3 | Creating CCE cluster of Kubernetes 1.17 | CCE clusters of Kubernetes 1.17 can be created. Kubernetes 1.17.9-r0 is released. Key features:
| Commercial use |
June 2020
| 1 | The everest add-on (CSI plug-in) of CCE v1.15 supports the functions of FlexVolume fuxi. | After upgrading CCE clusters earlier than v1.15 to v1.15, you can use the everest add-on to incorporate the functions of FlexVolume fuxi of an earlier version without interrupting services. | Commercial use | |
| 2 | A CCE cluster of v1.15.11 or later can manage a maximum of 2,000 nodes. | The maximum number of nodes that can be managed by a CCE cluster of v1.15.11 is increased to 2,000. You can choose the desired management scale of nodes according to your service requirement during creation. | Commercial use | |
| 3 | Creating CCE clusters of v1.15.11 |
| Commercial use | |
| 4 | CCE supports federated users. | EPS fine-grained authorization of CCE supports SAML federated users. Users can access CCE in SAML federated mode. | Commercial use |
May 2020
| 1 | CCE container storage supports dynamic creation of obsfs data volumes. | If a CCE cluster version is v1.15 or later and the everest add-on version is 1.0.2 or later, parallel file systems that can be mounted by obsfs can be created. | Commercial use |
