Help Center/ Cloud Container Engine_Autopilot/ User Guide/ Storage/ SFS Turbo/ (Recommended) Creating an SFS Turbo Subdirectory Using a Dynamic PV
Updated on 2026-09-15 GMT+08:00
There is a minimum capacity limit when you create an SFS Turbo volume, so you are not billed based on the capacity you have used. By default, when you mount an SFS Turbo volume to a workload, the root directory of the volume is mapped to the containers. The actual capacity used by the workload is far lower than the limit, leading to resource waste.
To make better use of storage capacity, CCE Autopilot enables you to create SFS Turbo subdirectories and configure the capacity of each subdirectory when you create a PVC. In this way, multiple workloads can share the same SFS Turbo file system.
  • If you want to create a cluster by running commands, kubectl has been used to connect to the cluster. For details, see Accessing a Cluster Using kubectl.
  • You have created an available SFS Turbo file system that is in the same VPC as the cluster.
  • Not all regions support SFS Turbo volumes. View the regions where SFS Turbo volumes are supported on the console.
  • To create subdirectories for an SFS Turbo volume, the cluster version must be v1.27.9-r0, v1.28.7-r0, or later. If the cluster version does not meet the requirements, you need to upgrade the cluster.
  • Constraints on the subdirectory quota:
    • If the subdirectory quota is less than 1 GiB, it is automatically set to 1 GiB. The maximum quota cannot exceed the capacity of the target SFS Turbo file system. The minimum scale-out step is 1 GiB, and capacity reduction is not allowed.
    • Once a subdirectory quota is configured, it cannot be canceled.
    • The number of files or subdirectories in a file system is determined by the quota capacity (in KB) divided by 16. The upper limit is set at 1 billion and cannot be changed by users.
Dynamically Creating an SFS Turbo Subdirectory
You can create PVCs for SFS Turbo subdirectories on the console or using kubectl based on the configured StorageClasses. After PVC creation, CCE dynamically allocates storage resources and mounts the PVCs to the specified workloads. To do so, perform the following operations:
  1. Log in to the CCE console and click the cluster name to go to the cluster console.
  2. In the navigation pane, choose Storage. Then click the PVCs tab. In the upper right corner, click Create PVC. In the displayed dialog box, configure the parameters.
    PVC Type
    In this example, select SFS Turbo.
    PVC Name
    Enter the PVC name, which must be unique in the same namespace.
    Namespace
    Namespace of the PVC.
    • In the navigation pane, choose Storage. If Namespace in the upper part of the page is All namespaces or Non-system namespace, you can select the target namespace.
    • If you choose Storage in the navigation pane and a non-system namespace (for example, default) has been specified for Namespace in the upper part of the page, the namespace is displayed here.
    Creation Method
    Select New subdirectory.
    Storage Classes
    Choose csi-sfsturbo.
    Access Mode
    SFS Turbo volumes support only ReadWriteMany, indicating that a storage volume can be mounted to multiple pods in read/write mode. For details, see Volume Access Modes.
    SFS Turbo
    Click Select SFS Turbo. On the displayed page, select the SFS Turbo file system that meets your requirements and click OK.
    Subdirectory
    Enter the absolute path of a subdirectory, for example, /a/b. If the subdirectory does not exist, a subdirectory is automatically created.
    Subdirectory Reclaim Policy
    Whether to retain subdirectories when a PVC is deleted.
    • Retain: If a PVC is deleted, the PV will be deleted, but the subdirectories associated with the PV will be retained.
    • Delete: After a PVC is deleted, the PV and its associated subdirectories will also be deleted.
      When a subdirectory is deleted, only the absolute path of the subdirectory configured in the PVC will be deleted. The upper-layer directory will not be deleted.
    Subdirectory Capacity
    • Unlimited: The subdirectory capacity is not limited.
    • Limited: The subdirectory capacity is limited.
    Capacity
    The maximum capacity of the subdirectory, in GiB. This parameter is only available when the subdirectory capacity limit is enabled.
  3. Click Create to create a PVC and a PV.
    In the navigation pane, choose Storage. View the created PVC and PV on the PVCs and PVs tabs, respectively.
  4. Create a workload.
    1. In the navigation pane, choose Workloads. Then click the Deployments tab.
    2. In the upper right corner, click Create Workload. In Container Settings, click Data Storage, then click Add Volume, and select PVC.
      Table 1 describes the parameters for mounting the volume. For details about other parameters, see Workloads.
      Table 1 Parameters for mounting a storage volume
      PVC
      Select an existing SFS Turbo volume.
      Mount Path
      Enter a mount path, for example, /tmp.
      This parameter indicates the container path that the volume will be mounted to. Do not mount the volume to a system directory such as / or /var/run. This may cause container errors. Mount the volume to an empty directory. If the directory is not empty, ensure that there are no files that affect container startup. If there are such files, they will be replaced, which will lead to a container startup or workload creation failure.
      NOTICE:
      If a volume is mounted to a high-risk directory, use an account with minimum permissions to start the container, or high-risk files on the host may be damaged.
      Subpath
      Enter a subdirectory of the PV. This subdirectory will be mounted to a specified path of a container. In this way, different subdirectories of the same PV can be used in a single pod. tmp, for example, indicates that data in the mount path of the container is stored in the tmp directory of the storage volume. If this parameter is left blank, the root path is used by default.
      Permission
      • Read-only: You can only read the data in the mounted volume.
      • Read-write: You can modify the volume mounted to the path. Newly written data will not be migrated if the container is migrated, which may cause data loss.
      In this example, the volume is mounted to the /data path of the container. The container data generated in this path is stored in the SFS Turbo file system.
      Figure 1 Mounting a PV
    3. Configure other parameters and click Create Workload.
      After the workload is created, the data in the container mount directory will be persistently stored. Verify the storage by referring to Verifying Data Persistence and Sharing.
  1. Use kubectl to connect to the cluster.
  2. Create the pvc-sfsturbo-subpath.yaml file.
    apiVersion: v1
    kind: PersistentVolumeClaim
      name: pvc-sfsturbo-subpath    # PVC name.
      namespace: default
      annotations:
        everest.io/volume-as: absolute-path                # An SFS Turbo subdirectory is used.
        everest.io/sfsturbo-share-id: <sfsturbo_id>        # SFS Turbo ID.
        everest.io/path: /a                                # Subdirectory that is automatically created, which must be an absolute path.
        everest.io/reclaim-policy: retain-volume-only      # When a PVC is deleted, the PV will be deleted, but the subdirectories associated with the PV will be retained.
        everest.io/csi.enable-sfsturbo-dir-quota: "true"   # Status of quota limit.
      accessModes:
        - ReadWriteMany      # ReadWriteMany must be selected for SFS Turbo.
      resources:
        requests:
          storage: 10Gi      # This configuration specifies the capacity of a subdirectory for an SFS Turbo subdirectory PVC when quota limit is enabled. In other scenarios, it is meaningless and only used for verification (the value cannot be empty or 0).
      storageClassName: csi-sfsturbo     # Storage class name of the SFS Turbo volume.
    Table 2 Key parameters
    Mandatory
    Yes
    The value is fixed at absolute-path, indicating that a dynamically created SFS Turbo subdirectory is used.
    Yes
    ID of an SFS Turbo file system.
    How to obtain: Log in to the SFS console, choose SFS Turbo > File Systems in the navigation pane, and copy the ID of the SFS Turbo file system.
    everest.io/path
    Yes
    Yes
    Whether to retain subdirectories when deleting a PVC. This parameter must be used with PV Reclaim Policy. This parameter is only available when the PV reclaim policy is Delete.
    • retain-volume-only: If a PVC is deleted, the PV will be deleted, but the subdirectories associated with the PV will be retained.
    • delete: After a PVC is deleted, the PV and its associated subdirectories will also be deleted.
    No
    Whether to limit the subdirectory capacity. If the value is set to true, the subdirectory capacity is limited. If the value is empty or set to any other value, the subdirectory capacity is not limited.
    storage
    Yes
    Requested capacity in the PVC, in Gi.
    For dynamically created subdirectories using a PVC:
    • If subdirectory capacity is limited, the value must be an integer.
      If storage is set to a decimal, the value will be rounded up automatically. For example, if storage is set to 10.1Gi, an 11-GiB subdirectory will be created.
    • If subdirectory capacity is not limited, this parameter is meaningless and is used only for verification. You can set this parameter to a fixed value 10Gi.
  3. Run the following command to create a PVC:
    kubectl apply -f pvc-sfsturbo-subpath.yaml
    1. Create a file named web-demo.yaml. In this example, the SFS Turbo volume is mounted to the /data path.
      apiVersion: apps/v1
      kind: Deployment
        namespace: default
        replicas: 2
        selector:
          matchLabels:
            app: web-demo
        template:
            labels:
              app: web-demo
            containers:
            - name: container-1
              image: nginx:latest
              volumeMounts:
              - name: pvc-sfsturbo-volume    #Volume name, which must be the same as the volume name in the volumes field.
                mountPath: /data  # Location where the storage volume is mounted.
            imagePullSecrets:
              - name: default-secret
            volumes:
              - name: pvc-sfsturbo-volume    # Volume name, which can be changed as needed.
                persistentVolumeClaim:
                  claimName: pvc-sfsturbo-subpath    # PVC name.
    2. Run the following command to create a workload that the SFS Turbo volume is mounted to:
      kubectl apply -f web-demo.yaml
      After the workload is created, you can verify it by referring to the procedure in Verifying Data Persistence and Sharing.
  1. View the deployed application and files.
    1. Run the following command to view the pods:
      kubectl get pod | grep web-demo
      Expected output:
      web-demo-846b489584-mjhm9   1/1     Running   0             46s
      web-demo-846b489584-wvv5s   1/1     Running   0             46s
    2. Run the following commands in sequence to view the files in the /data path of the pods:
      kubectl exec web-demo-846b489584-mjhm9 -- ls /data
      kubectl exec web-demo-846b489584-wvv5s -- ls /data
      If no result is returned for both pods, no file exists in the /data path.
  2. Run the following command to create a file named static in the /data path:
    kubectl exec web-demo-846b489584-mjhm9 --  touch /data/static
  3. Run the following command to view the created file in the /data path:
    Expected output:
    static
  4. Verify data persistence.
    1. Run the following command to delete the pod named web-demo-846b489584-mjhm9:
      kubectl delete pod web-demo-846b489584-mjhm9
      Expected output:
      pod "web-demo-846b489584-mjhm9" deleted
      After the deletion, the Deployment controller automatically creates a replica.
    2. Run the following command to view the pods:
      The expected output is as follows, in which web-demo-846b489584-d4d4j is the newly created pod:
      web-demo-846b489584-d4d4j   1/1     Running   0             110s
      web-demo-846b489584-wvv5s    1/1     Running   0             7m50s
    3. Run the following command to check whether the file in the /data path of the new pod has been modified:
      kubectl exec web-demo-846b489584-d4d4j -- ls /data
      Expected output:
      static
      The static file is retained, indicating that the data can be stored persistently.
  5. Verify data sharing.
      Expected output:
      web-demo-846b489584-d4d4j   1/1     Running   0             7m
      web-demo-846b489584-wvv5s   1/1     Running   0             13m
    2. Run the following command to create a file named share in the /data path of either pod: In this example, select the pod named web-demo-846b489584-d4d4j.
      kubectl exec web-demo-846b489584-d4d4j --  touch /data/share
      Check the files in the /data path of the pod.
      Expected output:
      share
      static
    3. Check whether the share file exists in the /data path of another pod (web-demo-846b489584-wvv5s) as well to verify data sharing.
      Expected output:
      share
      static
      After you create a file in the /data path of a pod, if the file is also created in the /data path of the other pod, the two pods share the same volume.
Related Operations
You can also perform the operations described in Table 3.
Table 3 Related operations
Operation
Steps
Viewing events
You can view event names, event types, number of occurrences, Kubernetes events, first occurrence time, and last occurrence time of the PVC or PV.
  1. In the navigation pane, choose Storage. Then click the PVCs or PVs tab.
  2. Locate the target PVC or PV and click View Events in the Operation column to view the events generated within one hour (events are retained for one hour).
Viewing a YAML file
You can view, copy, and download the YAML files of a PVC or PV.
  2. Locate the target PVC or PV, click View YAML in the Operation column to view or download the YAML.
Helpful Links
If a storage volume fails to mount to a workload, rectify the fault by referring to What Should I Do If a Storage Volume Cannot Be Mounted or the Mounting Times Out?
