Help Center/ Cloud Container Engine_Autopilot/ User Guide/ Storage/ SFS Turbo/ Configuring SFS Turbo Volume Mount Options
Updated on 2026-09-15 GMT+08:00
This section describes how to configure SFS Turbo volume mount options. For SFS Turbo, you can only set mount options in a PV and bind the PV by creating a PVC.
CCE Autopilot presets the options described in Table 1 for mounting SFS Turbo volumes.
Table 1 SFS Turbo mount options
Value
vers
3
File system version. Currently, only NFS v3 is supported. Value: 3
nolock
Leave it blank.
Whether to lock files on the server using the NLM protocol. If nolock is selected, the lock is valid for applications on one host. For applications on another host, the lock is invalid.
timeo
600
Waiting time before the NFS client retransmits a request. The unit is 0.1 seconds. Recommended value: 600
hard/soft
Leave it blank.
Mount mode.
  • hard: If the NFS request times out, the client keeps resending the request until the request is successful.
  • soft: If the NFS request times out, the client returns an error to the invoking program.
The default value is hard.
You can set other mount options if needed. For details, see Mounting an SFS Turbo File System to Linux ECSs.
Configuring Mount Options in a PV
You can use the mountOptions field to configure mount options in a PV. The options you can configure in mountOptions are listed in SFS Turbo Volume Mount Options.
  1. Use kubectl to connect to the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Configure mount options in a PV. The following is an example:
    apiVersion: v1
    kind: PersistentVolume
      annotations:
        pv.kubernetes.io/provisioned-by: everest-csi-provisioner
      name: pv-sfsturbo    # PV name.
      accessModes:
      - ReadWriteMany      # Access mode. The value must be ReadWriteMany for SFS Turbo.
      capacity:
        storage: 500Gi       # SFS Turbo volume capacity.
      csi:
        driver: sfsturbo.csi.everest.io    # Dependent storage driver for the mounting.
        fsType: nfs
        volumeHandle: {your_volume_id}   # SFS Turbo volume ID.
        volumeAttributes:
          everest.io/share-export-location: {your_location}   # Shared path of the SFS Turbo volume.
          everest.io/enterprise-project-id: {your_project_id}  # Project ID of the SFS Turbo volume.
          storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner
      persistentVolumeReclaimPolicy: Retain    # Reclaim policy.
      storageClassName: csi-sfsturbo           # Storage class name of the SFS Turbo volume.
      mountOptions:                            # Mount options.
      - vers=3
      - nolock
      - timeo=600
      - hard
  3. After a PV is created, you can create a PVC and bind it to the PV, and then mount the PV to the container in the workload. For details, see Creating an SFS Turbo Volume Statically.
  4. Check whether the mount options take effect.
    In this example, the PVC is mounted to the workload that uses the nginx:latest image. You can run the mount -l command to check whether the mount options take effect.
    1. View the pod to which the SFS Turbo volume has been mounted. In this example, the workload name is web-sfsturbo.
      kubectl get pod | grep web-sfsturbo
      Command output:
      web-sfsturbo-***   1/1     Running   0             23m
    2. Run the following command to check the mount options (web-sfsturbo-*** is an example pod):
      kubectl exec -it web-sfsturbo-*** -- mount -l | grep nfs
      If the mounting information in the command output is consistent with the configured mount options, the mount options have been configured.
      <Your mount path> on /data type nfs (rw,relatime,vers=3,rsize=1048576,wsize=1048576,namlen=255,hard,nolock,noresvport,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=**.**.**.**,mountvers=3,mountport=20048,mountproto=tcp,local_lock=all,addr=**.**.**.**)
