What's New
Updated on 2026/08/31 GMT+08:00
The tables below describe the functions released in each Log Tank Service version and corresponding documentation updates. New features will be successively launched in each region.
July 2026
July 01, 2026
No.
Feature
Phase
Document
Querying and analyzing website logs
You can use Log Tank Service (LTS) to query and analyze website logs.
Commercial use
June 2026
No.
Feature
Phase
Document
Configuring log alarm rules
When configuring a log alarm rule, you can apply it to other alarm rules and copy the source alarm rule to the target rule.
Commercial use
Configuring Log Alarm Rules
2
Adding custom wrapping rules
ECS text logs are ingested to LTS to support custom wrapping rules and repeated collection.
Commercial use
Managing ICAgent on hosts
3
text_search functions
The text_search functions are provided by LTS for searching logs by keyword. This feature supports text_search functions, including their syntax, parameters, and usage examples.
Commercial use
text_search Functions
May 2026
No.
Feature
Phase
Document
Implementing cross-account ingestion
With this function, you can implement unified management, real-time monitoring, and security isolation, thereby improving management efficiency and data security. This practice describes how to implement cross-account ingestion.
Commercial use
Implementing Cross-Account Ingestion
April 2026
No.
Feature
Phase
Document
Viewing CCE Application Logs on Charts
You can use SQL statements to query and analyze logs, and generate various statistical charts based on the analysis results to display log data and monitor trends. This best practice uses the CCE application logs ingested as an example to describe how the LTS displays CCE application logs on charts.
Commercial use
March 2026
No.
Feature
Phase
Document
ICAgent installation (intra-region hosts)
Methods of installing images are added.
Commercial use
Installing ICAgent (Intra-Region Hosts)
2
ICAgent Constraints
A maximum of 1,000 files can be monitored.
Commercial use
ICAgent Constraints
3
Date and Time Functions
The end time (__time_range__.end_time) and start time (__time_range__.start_time) for range query are added to date and time functions.
Commercial use
December 2025
No.
Feature
Phase
Document
ICAgent structuring parsing configuration
You can set up to 10 layers for JSON parsing.
Commercial use
Configuring ICAgent Structuring Parsing
2
Quick analysis
You can drag and drop a field to adjust its position.
Commercial use
Creating a Quick Analysis Task
3
Cloud structuring templates
Structuring templates for OBS bucket logs are added.
Commercial use
Setting a Structuring Template
4
Cloud service log ingestion to LTS
You can now ingest logs from a broader range of services, including Virtual Private Network (VPN), Domain Name Service (DNS), Cloud Connect, and Cloud Application Engine (CAE).
Commercial use
Overview
August 2025
No.
Feature
Phase
Document
Log transfer
Log transfer tasks can be deleted in batches.
Commercial use
Transferring Logs to OBS
2
Quick analysis
Quick analysis fields can be searched by field name.
Commercial use
3
Layout settings
The account-level or user-level layout can be configured.
Commercial use
Searching and Analyzing Logs
July 2025
No.
Feature
Phase
Document
Themes
Multiple themes are available.
Commercial use
Viewing Log Management
2
Log group search
Searching log groups by enterprise project is supported.
Commercial use
Managing Log Groups
3
Log stream search
Searching log streams by enterprise project is supported.
Commercial use
Managing Log Streams
4
Quick Start
A quick start area is added, showing how to quickly use LTS.
Commercial use
May 2025
No.
Feature
Phase
Document
Setting aliases for field names
When configuring indexing, you can set aliases for fields. Appropriate aliases can make your logs easier to read and maintain, improving query efficiency.
Commercial use
Creating a Log Index
2
Popular function module
The Popular Functions module is added to the Log Management page for easy access.
Commercial use
3
Two cloud structuring templates are added for TaurusDB audit logs and Workspace user operation logs.
Commercial use
4
Log transfer
Raw logs can be transferred to DMS.
Commercial use
Transferring Logs to DMS
April 2025
No.
Feature
Phase
Document
Dashboard templates
You can save custom dashboards as templates for easy reuse.
Commercial use
Creating a Dashboard
February 2025
No.
Feature
Phase
Document
ICAgent structuring parsing enables the parsing of JSON strings in JSON logs.
Commercial use
Setting ICAgent Structuring Parsing Rules
2
Alarm rules
An alarm rule name can contain up to 128 characters.
Commercial use
3
Tag management for alarm rules
You can tag alarm rules as required.
Commercial use
4
Log ingestion
Wrapping rules configured for log ingestion can be verified.
Commercial use
Using ICAgent to Collect Logs
August 2024
No.
Feature
Phase
Document
Log file code
Log file encoding supports Chinese Internal Code Extension Specification (GBK), which is a Chinese character encoding standard that extends both the ASCII and GB2312 encoding systems.
Commercial use
Ingesting CCE Application Logs to LTS
2
Minute-level traffic monitoring
You can check the resource usage details and top log groups or streams by resource usage on the resource statistics page.
Commercial use
3
Function enhancement
You can select the And or Or relationship when configuring Kubernetes label whitelists and Kubernetes label blacklists for log ingestion.
Commercial use
4
Repeated log collection
Logs from Cloud Container Engine (CCE), Elastic Cloud Server (ECS), and self-built Kubernetes can be repeatedly collected to LTS. This function is not available to Windows.
Commercial use
5
Query creation
You can create a query to search for log keywords.
Commercial use
Accessing the Log Search Page
6
Log alarms
You can search for alarm rules by name.
Commercial use
Viewing Alarms in LTS
7
Quick analysis
You can specify the number of samples for quick analysis. The value ranges from 100,000 (default) to 10 million. Quick analysis provides a fast overview by sampling field value statistics rather than analyzing all log data. The more logs sampled, the slower the analysis.
Commercial use
Setting Indexes
8
Log download
Up to 20 million logs can be downloaded at a time.
Commercial use
9
ICAgent supports parsing using regular expressions, delimiters, JSON, and combined plug-ins.
Commercial use
10
Style optimization
The operation buttons on the log alarm page are optimized to facilitate user identification.
Commercial use
July 2024
No.
Feature
Phase
Document
ICAgent collection
ICAgent for Windows supports host groups with identifiers, cross-cloud collection, and log collection error diagnosis.
Commercial use
Installing ICAgent (Extra-Region Hosts)
2
Log alarms
You can edit, export, and import alarm rules in batches.
Commercial use
3
Log transfer
You can add variable parameters when setting a custom path for transferring logs to OBS.
Commercial use
4
Index settings
You can configure full-text indexes and field indexes for each log stream separately and customize delimiter configurations.
Commercial use
Setting Indexes
5
Log ingestion
You can customize key-value pairs, the maximum size of a single log (up to 1 MB), and log file path depth (up to 20 levels) when configuring ingestion.
Commercial use
6
ICAgent collection diagnosis
Collection diagnosis dashboard templates are provided for monitoring exceptions, overall status, and collection status of ICAgent.
Commercial use
Setting ICAgent Collection
June 2024
No.
Feature
Phase
Document
Default delimiters
The backslash (\) and question mark (?) are added to default delimiters.
Commercial use
Configuring Log Content Delimiters
2
Log ingestion
The standard output and standard error output can be collected to different files (stdout.log and stderr.log) or the same file (stdout.log).
Commercial use
3
A system template for GeminiDB Mongo audit logs is added.
Commercial use
Selecting a Cloud Structuring Template
May 2024
No.
Feature
Phase
Document
Batch connection
Log ingestion rules can be created in batches for services such as Bare Metal Server (BMS), Cloud Container Engine (CCE), and Elastic Cloud Server (ECS).
Commercial use
2
Dashboards
Enterprise projects can be selected for dashboards.
Commercial use
3
Metric generation
You can create log metric rules to extract metrics from log data reported to LTS for central management.
Open beta testing
Generating Metrics from Logs
4
Custom identifiers
You can set custom identifiers when creating host groups of the Windows type.
Commercial use
Managing Host Groups
5
Log groups
Enterprise projects can be selected for log groups.
Commercial use
Managing Log Groups
April 2024
No.
Feature
Phase
Document
Simple noise reduction for alarms
The notification frequency can be set for log alarms to prevent alarm storms.
Commercial use
Alarm Rules
2
ServiceStage log collection
Containerized application logs of ServiceStage can be ingested to LTS.
Commercial use
Collecting Logs from ServiceStage - Containerized Applications
3
Alarm action rules
You can create an alarm action rule and bind it with a message template.
Commercial use
Creating an Alarm Action Rule
June 2023
No.
Feature
Phase
Document
CCE event logs
CCE K8s event logs can be collected.
Commercial use
Collecting Logs from CCE
2
Logs of mounted container files can be collected.
CCE log collection allows ICAgent to collect logs of mounted container files.
Commercial use
3
Layout settings can be customized.
Layout settings can be customized on the page of log search.
Commercial use
Log Search
4
Retention duration
The log retention duration can be set to 10 years. This function is available only for whitelisted users in internal tests.
Open beta testing
Log Groups
May 2023
No.
Feature
Phase
Document
Collection configurations can be verified.
When logs are collected from CCE, regular expressions can be verified on the collection configuration page.
Commercial use
2
The names of log groups and log streams can be changed.
After a log group and a log stream are created, you can change their names. The original names cannot be changed.
Commercial use
Log Groups
3
The simple view is added to viewing context.
On the page of viewing context, you can set the simple view to quickly browse logs by omitting information such as the log time.
Commercial use
Log Search
April 2023
No.
Feature
Phase
Document
Quick search
The quota of statements that can be quickly searched for in a single log stream increases from 10 to 50.
Commercial use
Quick Search
2
Optimized real-time log display
Real-time log display adopts real-time scrolling to improve the display effect.
Commercial use
Viewing Real-Time Logs
3
Interactive search
Interactive search is added for you to quickly add query statements to lower the search threshold.
Commercial use
Log Search
4
Optimized charts
Configuration items of table charts, line charts, pie charts, bar charts, and number charts are optimized.
Commercial use
Statistical Charts
5
Log stream tags
After a tag is added to a log stream, the log stream tag information is displayed in the reported charging data record (CDR). This helps you analyze fees by resource tag (log stream tag) in the billing center.
Commercial use
Best Practices
March 2023
No.
Feature
Phase
Document
Index settings
You can configure full-text indexes and field indexes for each log stream separately to customize delimiter configuration.
Commercial use
Index Settings
2
Delimiter containing multiple characters
A delimiter can contain multiple characters.
Commercial use
Structuring Modes
3
Alarm rules
  • Alarms can be enabled, disabled, and temporarily disabled in batches, improving editing efficiency.
  • Alarm rules can be renamed.
  • Alarms can be copied.
Commercial use
Alarm Rules
4
Custom delimiters
You can customize delimiters for full-text indexes and field indexes.
Open beta testing
Structuring Modes
5
Log ingestion
LTS can collect logs from self-built K8s clusters.
Open beta testing
Self-Built Kubernetes
February 2023
No.
Feature
Phase
Document
Optimized custom log time
When logs are ingested to LTS, you can enable Custom Log Time to set the time field in the logs as the ingested configuration time.
Commercial use
Customizing the Log Time
2
Log structuring templates
Added the templates of structuring GaussDB(for Cassandra) slow logs, MySQL audit logs, GaussDB(for Mongo) error logs, and GaussDB(for Mongo) slow logs.
Open beta testing
Structuring Templates
3
Dashboard templates
Provided ER dashboard templates.
Open beta testing
Dashboard Templates
January 2023
No.
Feature
Phase
Document
Dashboard templates
Provided VPC dashboard templates.
Open beta testing
Dashboard Templates
December 2022
No.
Feature
Phase
Document
Dashboard templates
Provided CDN dashboard templates.
Open beta testing
Dashboard Templates
2
Filters
The dynamic value source in the filter can be fuzzy match.
Open beta testing
Filters
November 2022
No.
Feature
Phase
Document
Custom identifier host group
You can create a host group with a custom identifier that is added automatically.
Open beta testing
Custom Identifier
2
Adding a log stream to favorites
Favorite log streams can be displayed in two modes: My Favorites and My Favorites (Local Cache).
Open beta testing
LTS Console
3
Added the templates for structuring SQL Server error logs and GaussDB(for Redis) slow logs.
Open beta testing
Log Structuring
October 2022
No.
Feature
Phase
Document
Function jobs
You can create functions from templates or scratch to normalize, transfer, anonymize, and filter logs.
Open beta testing
Function Processing
2
Index settings
You can query and analyze logs after setting indexes.
Open beta testing
Index Settings
3
Creating alarms in batches
You can select multiple log streams to create keyword alarms.
Commercial use
Log Alarms
September 2022
No.
Feature
Phase
Document
Dashboard templates
Provided APIG, Nginx, and CFW dashboard templates.
Open beta testing
Dashboard Templates
2
Log ingestion
The console provides guided ingestion of ELB, APIG, and CTS logs.
Commercial use
Collecting Logs from Cloud Services
3
Log search syntax
Search syntaxes such as *, in, (), and key:#"abc def" are supported.
Commercial use
Log Search
August 2022
No.
Feature
Phase
Document
Added the structuring configuration templates for Tomcat, DDS, and DCS.
Commercial use
Log Structuring
2
Dashboard templates
Provided DCS, DDS, and ELB dashboard templates.
Open beta testing
Dashboard Templates
3
Usage alerts
If the log resource usage exceeds a specified limit, the system gives an alarm.
Commercial use
Configuring Usage Alerts
July 2022
No.
Feature
Phase
Document
Collecting logs from CCE
Logs from CCE can be collected.
Commercial use
2
Custom log time
By default, the log time is the time configured in log ingestion. You can enable User-defined log time to customize the log time.
Commercial use
Custom log time
3
Search tips
During log search, you can press Tab to automatically add the first keyword displayed in the drop-down list.
Commercial use
Log Search
June 2022
No.
Feature
Phase
Document
Optimized log context display
When viewing the context, you can query the number of rows, highlight log content, and filter logs.
Commercial use
Quick Search
May 2022
No.
Feature
Phase
Document
Cross-account ingestion
If you use the Cross-Account Ingestion - Log Stream Mapping, logs of the delegator account are ingested to LTS.
Commercial use
April 2022
No.
Feature
Phase
Document
New log search page
The new page provides log sharing, simplified field details, and layout setting.
Commercial use
Log Search
March 2022
No.
Feature
Phase
Document
Resource statistics
Statistics of log index traffic, read/write traffic, and storage usage are displayed.
Commercial use
Resource Statistics
January 2022
No.
Feature
Phase
Document
Tag transfer
Tags can be transferred along with logs.
Commercial use
November 2021
No.
Feature
Phase
Document
Tag fields
Logs can be filtered by tag fields during transfer.
Commercial use
October 2021
No.
Feature
Phase
Document
Time zone setting
Time zone can be configured for log transfer.
Commercial use
September 2021
No.
Feature
Phase
Document
Log transfer delegation
You can transfer logs for another account as long as you have been delegated.
Commercial use
2
Transfer to encrypted OBS buckets
You can transfer logs to an encrypted OBS bucket.
Commercial use
July 2021
No.
Feature
Phase
Document
Log ingestion wizard
Step-by-step wizard for ingesting logs from hosts.
Commercial use
Log Ingestion
2
Host management
Host groups and log ingestion configurations can be associated with each other. This allows you to modify the log collection paths of multiple hosts at a go.
Commercial use
April 2021
No.
Feature
Phase
Document
Log ingestion using APIs
You can use APIs to ingest logs.
Commercial use
Collecting Logs Using APIs
2
Delimiters
You can configure delimiters to split log content into words, so you can search for logs by these words.
Commercial use
Configuring Delimiters
3
You can ingest logs from different cloud services.
Commercial use
March 2021
No.
Feature
Phase
Document
Custom structuring templates
You can create structuring templates for quick reuse.
Commercial use
Structuring Logs
February 2021
No.
Feature
Phase
Document
Nginx log structuring
You can parse logs in standard Nginx format.
Commercial use
Structuring Modes
December 2020
No.
Feature
Phase
Document
JSON, delimiters, and system templates
You can parse logs in standard JSON format, and parse logs using delimiters (such as commas and spaces) or ELB, VPC, and CTS structuring templates.
Commercial use
Structuring Logs
July 2020
No.
Feature
Phase
Document
Log search
You can filter logs by fields.
Commercial use
Log Search
June 2020
No.
Feature
Phase
Document
Open APIs
APIs for managing log groups and log streams are available.
Commercial use
Creating a Log Group
April 2020
No.
Feature
Phase
Document
Log structuring and SQL query
You can structure logs, and use SQL statements to query and analyze structured logs.
Commercial use
Structuring Logs
October 2019
No.
Feature
Phase
Document
Transferring Logs to DIS
You can transfer logs to Data Ingestion Service (DIS) and further transmit the logs through DIS to EI. DIS supports both log storage and big data analysis. To be specific, DIS can transfer a large number of log files to the cloud for backup, offline analysis, query, and machine learning. In addition, You can use DIS for data recovery and fault analysis after data loss or exceptions. During transfer, a large number of small text files can be merged into a large file to accelerate data processing.
Commercial use
