Spark SQL Syntax
This section describes the Spark SQL syntax list provided by DLI. For details about the parameters and examples, see the syntax description.
| Classification | Reference |
| Database-related Syntax | |
| Syntax for Creating an OBS Table | |
| Syntax for Creating a DLI Table | |
| Syntax for Deleting a Table | |
| Syntax for Checking a Table | |
| Syntax for Modifying a Table | |
| Syntax for Partitioning a Table | |
| Altering the Partition Location of a Table (Only OBS Tables Supported) | |
| Syntax for Importing Data | |
| Syntax for Inserting Data | |
| Syntax for Clearing Data | |
| Syntax for Exporting Query Results | |
| Syntax for Datasource Connection to an HBase Table | |
| Syntax for Datasource Connection to an OpenTSDB Table | |
| Syntax for Datasource Connection to a GaussDB(DWS) Table | |
| Syntax for Datasource Connection to an RDS Table | |
| Syntax for Datasource Connection to a CSS Table | |
| Syntax for Datasource Connection to a DCS Table | |
| Syntax for Datasource Connection to a DDS Table | |
| View-related Syntax | |
| Syntax for Checking the Execution Plan | |
| Syntax Related to Data Permissions | |
| Displaying the Binding Relationship Between All Roles and Users | |
| UDF-related Syntax | |
| Data Multi-Versioning-related Syntax (Deprecated, Not Recommended) | Enabling Multiversion Backup When Creating an OBS Table Enabling or Disabling Multiversion Backup When Modifying a Table Setting the Retention Period for Multiversion Backup Data Checking Multiversion Backup Data Restoring Multiversion Backup Data |
