Updated on 2024-07-04 GMT+08:00
Deleting a Database
Function
This statement is used to delete a database.
Syntax
DROP [DATABASE | SCHEMA] [IF EXISTS] db_name [RESTRICT|CASCADE];
Keywords
IF EXISTS: Prevents system errors if the database to be deleted does not exist.
Precautions
  • DATABASE and SCHEMA can be used interchangeably. You are advised to use DATABASE.
  • RESTRICT: If the database is not empty (tables exist), an error is reported and the DROP operation fails. RESTRICT is the default logic.
  • CASCADE: Even if the database is not empty (tables exist), the DROP will delete all the tables in the database. Therefore, exercise caution when using this function.
Parameters
Table 1 Parameter
db_name
Database name, which consists of letters, digits, and underscores (_). The value cannot contain only digits or start with a digit or underscore (_).
Example
  1. Create a database, for example, testdb, by referring to Example.
  2. Run the following statement to delete database testdb if it exists:
    DROP DATABASE IF EXISTS testdb;
