Viewing a Specified Database
Function
This syntax is used to view the information about a specified database, including the database name and database description.
Syntax
1 | DESCRIBE DATABASE [EXTENDED] db_name; |
Keywords
EXTENDED: Displays the database properties.
Parameters
Parameter | Description |
db_name | Database name, which consists of letters, digits, and underscores (_). The value cannot contain only digits or start with a digit or underscore (_). |
Precautions
If the database to be viewed does not exist, the system reports an error.
Example
- Create a database, for example, testdb, by referring to Example.
- Run the following statement to query information about the testdb database:
1DESCRIBE DATABASE testdb;
