Creating a Database
Function
This statement is used to create a database.
Syntax
1 2 3 |
CREATE [DATABASE | SCHEMA] [IF NOT EXISTS] db_name [COMMENT db_comment] [WITH DBPROPERTIES (property_name=property_value, ...)]; |
Keywords
- IF NOT EXISTS: Prevents system errors if the database to be created exists.
- COMMENT: Describes a database.
- DBPROPERTIES: Specifies database attributes. The attribute name and attribute value appear in pairs.
Parameters
Parameter |
Description |
db_name |
Database name, which consists of letters, digits, and underscores (_). The value cannot contain only digits or start with a digit or underscore (_). |
db_comment |
Database description |
property_name |
Database property name |
property_value |
Database property value |
Precautions
- DATABASE and SCHEMA can be used interchangeably. You are advised to use DATABASE.
- The default database is a built-in database. You cannot create a database named default.
Example
- Create a queue. A queue is the basis for using DLI. Before executing SQL statements, you need to create a queue. For details, see Creating a Queue.
- On the DLI management console, click SQL Editor in the navigation pane on the left. The SQL Editor page is displayed.
- In the editing window on the right of the SQL Editor page, enter the following SQL statement for creating a database and click Execute. Read and agree to the privacy agreement, and click OK.
If database testdb does not exist, run the following statement to create database testdb:
CREATE DATABASE IF NOT EXISTS testdb;
