Updated on 2024-07-04 GMT+08:00
Viewing Table Statistics
Function
This statement is used to check table statistics. The names and data types of all columns in a specified table will be returned.
Syntax
DESCRIBE [EXTENDED|FORMATTED] [db_name.]table_name;
Keywords
  • EXTENDED: displays all metadata of the specified table. It is used during debugging in general.
  • FORMATTED: displays all metadata of the specified table in a form.
Parameters
Table 1 Parameters
db_name
Database name that contains letters, digits, and underscores (_). It cannot contain only digits or start with an underscore (_).
table_name
Table name of a database that contains letters, digits, and underscores (_). It cannot contain only digits or start with an underscore (_). The matching rule is ^(?!_)(?![0-9]+$)[A-Za-z0-9_$]*$. If special characters are required, use single quotation marks ('') to enclose them.
Precautions
The to-be-queried table must exist. If this statement is used to query the information about a table that does not exist, an error is reported.
Example
To query the names and data types of all columns in the student table, run the following statement:
DESCRIBE student;
