Updated on 2024-07-04 GMT+08:00
Adding a Column
Function
This statement is used to add one or more new columns to a table.
Syntax
ALTER TABLE [db_name.]table_name ADD COLUMNS (col_name1 col_type1 [COMMENT col_comment1], ...);
Keywords
  • ADD COLUMNS: columns to add
  • COMMENT: column description
Parameters
Table 1 Parameters
db_name
Database name that contains letters, digits, and underscores (_). It cannot contain only digits or start with an underscore (_).
table_name
Table name
col_name
Column name
col_type
Field type
col_comment
Column description
Precautions
Do not run this SQL statement concurrently. Otherwise, columns may be overwritten.
Example
ALTER TABLE t1 ADD COLUMNS (column2 int, column3 string);
