Modifying Column Comments
Function
You can modify the column comments of non-partitioned or partitioned tables.
Syntax
ALTER TABLE [db_name.]table_name CHANGE COLUMN col_name col_name col_type COMMENT 'col_comment';
Keywords
- CHANGE COLUMN: Modify a column.
 - COMMENT: column description
Parameters
        Parameter  |
        Mandatory  |
        Description  |
        db_name  |
        No  |
        Database name. Only letters, digits, and underscores (_) are allowed. The name cannot contain only digits or start with an underscore (_).  |
        table_name  |
        Yes  |
        Table name  |
        col_name  |
        Yes  |
        Column name. The value must be the name of an existing column.  |
        col_type  |
        Yes  |
        Column data type specified when the table is created, which cannot be modified.  |
        col_comment  |
        Yes  |
        Column comment after modification. The comment can contain a maximum of 1024 bytes.  |
Example
Change the comment of the c1 column in the t1 table to the new comment.
        ALTER TABLE t1 CHANGE COLUMN c1 c1 STRING COMMENT 'the new comment';  |
