Updated on 2024-07-04 GMT+08:00
Granting a Permission
Function
This statement is used to grant permissions to a user or role.
Syntax
GRANT (privilege,...) ON (resource,..) TO ((ROLE [db_name].role_name) | (USER user_name)),...);
Keywords
ROLE: The subsequent role_name must be a role.
USER: The subsequent user_name must be a user.
Precautions
  • The privilege must be one of the authorizable permissions. If the object has the corresponding permission on the resource or the upper-level resource, the permission fails to be granted. For details about the permission types supported by the privilege, see Data Permissions List.
  • The resource can be a queue, database, table, view, or column. The formats are as follows:
    • Queue format: queues.queue_name
      The following table lists the permission types supported by a queue.
      Operation
      DROP_QUEUE
      Deleting a queue
      SUBMIT_JOB
      Submitting a job
      CANCEL_JOB
      Cancel a job
      RESTART
      Restarting a queue
      SCALE_QUEUE
      Scaling out/in a queue
      GRANT_PRIVILEGE
      Granting queue permissions
      REVOKE_PRIVILEGE
      Revoking queue permissions
      SHOW_PRIVILEGES
      Checking queue permissions of other users
    • Database format: databases.db_name
      For details about the permission types supported by a database, see Data Permissions List.
    • Table format: databases.db_name.tables.table_name
      For details about the permission types supported by a table, see Data Permissions List.
    • View format: databases.db_name.tables.view_name
      Permission types supported by a view are the same as those supported by a table. For details, see table permissions in Data Permissions List.
    • Column format: databases.db_name.tables.table_name.columns.column_name
      Columns support only the SELECT permission.
Example
Run the following statement to grant user_name1 the permission to delete the db1 database:
GRANT DROP_DATABASE ON databases.db1 TO USER user_name1;
Run the following statement to grant user_name1 the SELECT permission of data table tb1 in the db1 database:
GRANT SELECT ON databases.db1.tables.tb1 TO USER user_name1;
Run the following statement to grant role_name the SELECT permission of data table tb1 in the db1 database:
GRANT SELECT ON databases.db1.tables.tb1 TO ROLE role_name;
