Help Center/Data Lake Insight/Spark SQL Syntax Reference/Tables/Partition-related Syntax/Updating Partitioned Table Data (Only OBS Tables Supported)
Updated on 2024-07-04 GMT+08:00
Function
This statement is used to update the partition information about a table in the Metastore.
Syntax
MSCK REPAIR TABLE table_name;
Or
ALTER TABLE table_name RECOVER PARTITIONS;
Keywords
  • PARTITIONS: partition information
  • SERDEPROPERTIES: Serde attribute
Parameters
Table 1 Parameters
table_name
Table name
partition_specs
Partition fields
obs_path
OBS path
Precautions
  • This statement is applied only to partitioned tables. After you manually add partition directories to OBS, run this statement to update the newly added partition information in the metastore. The SHOW PARTITIONS table_name statement can be used to query the newly-added partitions.
  • The partition directory name must be in the specified format, that is, tablepath/partition_column_name=partition_column_value.
Example
Run the following statements to update the partition information about table ptable in the Metastore:
MSCK REPAIR TABLE ptable;
Or
ALTER TABLE ptable RECOVER PARTITIONS;
