Updated on 2024-07-04 GMT+08:00
Updating Table Metadata with REFRESH TABLE
Function
Spark caches Parquet metadata to improve performance. If you update a Parquet table, the cached metadata is not updated. Spark SQL cannot find the newly inserted data and an error similar with the following is reported:
DLI.0002: FileNotFoundException: getFileStatus on  error message
You can use REFRESH TABLE to solve this problem. REFRESH TABLE reorganizes files of a partition and reuses the original table metadata information to detect the increase or decrease of table fields. This statement is mainly used when the metadata in a table is not modified but the table data is modified.
Syntax
REFRESH TABLE [db_name.]table_name;
Keywords
None
Parameters
Table 1 Parameters
db_name
Database name that contains letters, digits, and underscores (_). It cannot contain only digits or start with an underscore (_).
table_name
Table name of a database that contains letters, digits, and underscores (_). It cannot contain only digits or start with an underscore (_). The matching rule is ^(?!_)(?![0-9]+$)[A-Za-z0-9_$]*$. If special characters are required, use single quotation marks ('') to enclose them.
Precautions
None
Example
Update metadata of the test table.
REFRESH TABLE test;
