Help Center/Data Lake Insight/Spark SQL Syntax Reference/Tables/Partition-related Syntax/Altering the Partition Location of a Table (Only OBS Tables Supported)
Updated on 2024-07-04 GMT+08:00
Function
This statement is used to modify the positions of table partitions.
Syntax
3
ALTER TABLE table_name
  PARTITION partition_specs
  SET LOCATION obs_path;
Keywords
  • PARTITION: a specified partition
Parameters
Table 1 Parameters
table_name
Table name
partition_specs
Partition fields
obs_path
OBS path
Precautions
  • For a table partition whose position is to be modified, the table and partition must exist. Otherwise, an error is reported.
  • By default, the partition_specs parameter contains (). For example: PARTITION (dt='2009-09-09',city='xxx')
  • The specified OBS path must be an absolute path. Otherwise, an error is reported.
  • If the path specified in the new partition contains subdirectories (or nested subdirectories), all file types and content in the subdirectories are considered partition records. Ensure that all file types and file content in the partition directory are the same as those in the table. Otherwise, an error is reported.
Example
To set the OBS path of partition dt='2008-08-08',city='xxx' in table student to obs://bucketName/fileName/student/dt=2008-08-08/city=xxx, run the following statement:
3
ALTER TABLE student
  PARTITION(dt='2008-08-08',city='xxx')
  SET LOCATION 'obs://bucketName/fileName/student/dt=2008-08-08/city=xxx';
