Help Center>
Data Lake Insight>
Spark SQL Syntax Reference>
Datasource Connections>
Creating a Datasource Connection with a DCS Table>
Querying the DCS Table
Updated on 2024-07-04 GMT+08:00
This statement is used to query data in a DCS table.
Syntax
SELECT * FROM table_name LIMIT number; |
Keywords
LIMIT is used to limit the query results. Only INT type is supported by the number parameter.
Example
Query data in the test_redis table.
SELECT * FROM test_redis limit 100; |
Parent topic: Creating a Datasource Connection with a DCS Table
