Inserting Data to a DCS Table
Function
This statement is used to insert data in a DLI table to the DCS key.
Syntax
- Insert the SELECT query result into a table.
1 2 3 4 5 6 7
INSERT INTO DLI_TABLE SELECT field1,field2... [FROM DLI_TEST] [WHERE where_condition] [LIMIT num] [GROUP BY field] [ORDER BY field] ...;
- Insert a data record into a table.
1 2
INSERT INTO DLI_TABLE VALUES values_row [, values_row ...];
Keywords
For details about the SELECT keywords, see Basic Statements.
Parameters
| Parameter | Description |
| DLI_TABLE | Name of the DLI table for which a datasource connection has been created. |
| DLI_TEST | indicates the table that contains the data to be queried. |
| field1,field2..., field | Column values in the DLI_TEST table must match the column values and types in the DLI_TABLE table. |
| where_condition | Query condition. |
| num | Limit the query result. The num parameter supports only the INT type. |
| values_row | Value to be inserted to a table. Use commas (,) to separate columns. |
Precautions
- A DLI table is available.
- When creating a DLI table, you need to specify the schema information.
- If key.column is specified during table creation, the value of the specified field is used as a part of the Redis key name. The following is an example:
1 2 3 4 5 6 7 8
create table test_redis(name string, age int) using redis options( 'host' = '192.168.4.199', 'port' = '6379', 'passwdauth' = '******', 'table' = 'test_with_key_column', 'key.column' = 'name' ); insert into test_redis values("James", 35), ("Michael", 22);
The Redis database contains two tables, naming test_with_key_column:James and test_with_key_column:Michael respectively.
- If key.column is not specified during table creation, the key name in Redis uses the UUID. The following is an example:
1 2 3 4 5 6 7
create table test_redis(name string, age int) using redis options( 'host' = '192.168.7.238', 'port' = '6379', 'passwdauth' = '******', 'table' = 'test_without_key_column' ); insert into test_redis values("James", 35), ("Michael", 22);
In Redis, there are two tables named test_without_key_column:uuid.
Example
1 2 | INSERT INTO test_redis VALUES("James", 35), ("Michael", 22); |
