Updated on 2024-07-04 GMT+08:00
Inserting Data to the OpenTSDB Table
Function
Run the INSERT INTO statement to insert the data in the DLI table to the associated OpenTSDB metric.
If no metric exists on the OpenTSDB, a new metric is automatically created on the OpenTSDB when data is inserted.
Syntax
INSERT INTO TABLE TABLE_NAME SELECT * FROM DLI_TABLE;
INSERT INTO TABLE TABLE_NAME VALUES(XXX);
Keywords
Table 1 INSERT INTO keywords
TABLE_NAME
Name of the associated OpenTSDB table.
DLI_TABLE
Name of the DLI table created.
Precautions
  • The inserted data cannot be null. If the inserted data is the same as the original data or only the value is different, the inserted data overwrites the original data.
  • INSERT OVERWRITE is not supported.
  • You are advised not to concurrently insert data into a table. If you concurrently insert data into a table, there is a possibility that conflicts occur, leading to failed data insertion.
  • The TIMESTAMP format supports only yyyy-MM-dd hh:mm:ss.
Example
INSERT INTO TABLE opentsdb_table VALUES('xxx','xxx','2018-05-03 00:00:00',21);
