Viewing Table Creation Statements
Function
This statement is used to show the statements for creating a table.
Syntax
1 | SHOW CREATE TABLE table_name; |
Use the following syntax to view table creation statements when using Spark 3.3.1 (this applies only to querying table creation statements for Hive tables):
1 | SHOW CREATE TABLE table_name AS SERDE; |
Keywords
CREATE TABLE: statement for creating a table
Parameters
Parameter | Description |
table_name | Table name |
Precautions
The table specified in this statement must exist. Otherwise, an error will occur.
Example
- Run the following command to return the statement for creating the testDB01.testTable5 table:
SHOW CREATE TABLE testDB01.testTable5
- Return the statement for creating the test table.
createtab_stmt CREATE TABLE `testDB01`.`testTable5`(`id` INT, `age` INT, `money` DOUBLE) COMMENT 'test' ROW FORMAT SERDE 'org.apache.hadoop.hive.ql.io.parquet.serde.ParquetHiveSerDe' WITH SERDEPROPERTIES ( 'serialization.format' = '1' ) STORED AS INPUTFORMAT 'org.apache.hadoop.hive.ql.io.parquet.MapredParquetInputFormat' OUTPUTFORMAT 'org.apache.hadoop.hive.ql.io.parquet.MapredParquetOutputFormat' TBLPROPERTIES ( 'hive.serialization.extend.nesting.levels' = 'true', 'ddlUpdateTime' = '1707202585460' )
- Run the following command to return the statement for creating the testDB02.testTable5 table:
SHOW CREATE TABLE testDB02.testTable5 AS SERDE
createtab_stmt CREATE TABLE testDB02.testTable5 ( id INT, age INT, money DOUBLE) ROW FORMAT SERDE 'org.apache.hadoop.hive.ql.io.parquet.serde.ParquetHiveSerDe' WITH SERDEPROPERTIES ( 'serialization.format' = '1') STORED AS INPUTFORMAT 'org.apache.hadoop.hive.ql.io.parquet.MapredParquetInputFormat' OUTPUTFORMAT 'org.apache.hadoop.hive.ql.io.parquet.MapredParquetOutputFormat' TBLPROPERTIES ( 'hive.serialization.extend.nesting.levels' = 'true', 'transient_lastDdlTime' = '1707201874')
