Querying the CSS Table
This statement is used to query data in a CSS table.
Syntax
1 | SELECT * FROM table_name LIMIT number; |
Keywords
LIMIT is used to limit the query results. Only INT type is supported by the number parameter.
Precautions
The table to be queried must exist. Otherwise, an error is reported.
Example
To query data in the dli_to_css table, enter the following statement:
1 | SELECT * FROM dli_to_css limit 100; |
