Updated on 2024-07-04 GMT+08:00
Viewing the Execution Plan
Function
This statement returns the logical plan and physical execution plan for the SQL statement.
Syntax
EXPLAIN [EXTENDED | CODEGEN] statement;
Keywords
EXTENDED: After this keyword is specified, the logical and physical plans are outputted at the same time.
CODEGEN: After this keyword is specified, code generated by using the Codegen is also outputted.
Precautions
None
Example
To return the logical and physical plans of SELECT * FROM test, run the following statement:
EXPLAIN EXTENDED select * from test;
