Viewing Multi-Versioning Backup Data (Deprecated, Not Recommended)
Function
The multi-versioning feature is to be deprecated and is not recommended. Recommended functions: Hudi multi-versioning cleanup and Hudi archive.
After the multiversion function is enabled, you can run the SHOW HISTORY command to view the backup data of a table. For details about the syntax for enabling or disabling the multiversion function, see Enabling or Disabling Data Multi-Versioning (Deprecated, Not Recommended).
Currently, the multiversion function supports only OBS tables created using the Hive syntax. For details about the syntax for creating a table, see Creating an OBS Table Using the Hive Syntax.
Syntax
- View the backup data of a non-partitioned table.
SHOW HISTORY FOR TABLE [db_name.]table_name;
- View the backup data of a specified partition.
SHOW HISTORY FOR TABLE [db_name.]table_name PARTITION (column = value, ...);
Keywords
- SHOW HISTORY FOR TABLE: Used to view backup data
- PARTITION: Used to specify the partition column
Parameters
Parameter | Description |
db_name | Database name, which consists of letters, digits, and underscores (_). The value cannot contain only digits or start with a digit or underscore (_). |
table_name | Table name |
column | Partition column name |
value | Value corresponding to the partition column name |
Precautions
Example
- View multiversion backup data of the test_table table.
1SHOW HISTORY FOR TABLE test_table;
- View multiversion backup data of the dt partition in the test_table partitioned table.
1SHOW HISTORY FOR TABLE test_table PARTITION (dt='2021-07-27');
