What's New
Updated on 2025/10/31 GMT+08:00
The tables below describe the functions released in each CodeArts Pipeline version and corresponding documentation updates. New features will be successively launched in each region.
March 2025
No.
Feature
Phase
Document
Job template
You can create a job template and reference it in multiple pipelines.
Commercial use
Configuring a Job Template
2
Adding custom extensions to a pipeline template
You can add official, third-party, and custom extensions to a pipeline template.
Commercial use
Managing Pipeline Templates
3
Checking tenant-level pipeline statistics
The pipeline statistics dashboard displays pipelines, their execution statuses, parallel executions in the system and in each project.
Commercial use
Checking the Dashboard
4
Using functions in expressions
More built-in functions are available for you to configure expressions.
Commercial use
Configuring Expressions
November 2024
No.
Feature
Phase
Document
Customizing an extension
When you configure a custom extension during pipeline orchestration, you can add option values for the drop-down selection widget.
Commercial use
Orchestrating Pipeline Jobs
2
Adding or deleting pipeline parameters
You can add or delete parameters in any row of the pipeline parameter list.
Commercial use
Configuring Pipeline Parameters
3
Searching for an extension task
You can search for a task after you add an official extension such as Build or Deploy.
Commercial use
4
Service details page
You can click the failed job card to check the failing reason.
Commercial use
Checking a Pipeline
5
Checking execution history
The Job Details field is added. You can set whether to display it.
Commercial use
Checking a Pipeline
September 2024
No.
Feature
Phase
Document
Refreshing CodeArts Pipeline documentation
Optimized the structure and content to improve user experience.
Commercial use
August 2024
No.
Feature
Phase
Document
Scheduled task
You can configure execution plans to execute pipelines periodically.
Commercial use
Configuring Pipeline Execution Plans
2
Task configuration
More task configuration options are available: Always, Disabled, Selected by default, and Not selected by default.
Commercial use
July 2024
No.
Feature
Phase
Document
YAML-based orchestration
You can orchestrate pipelines with YAML.
Commercial use
Creating a Pipeline with YAML
June 2024
No.
Feature
Phase
Document
Parameter groups
You can use the same set of parameters in multiple pipelines.
Commercial use
May 2024
No.
Feature
Phase
Document
Stage admission
Added the time window setting.
Commercial use
Orchestrating Pipeline Stages
March 2024
No.
Feature
Phase
Document
Delayed execution
The delay duration is clearly displayed.
Commercial use
Pipeline Official Extensions
February 2024
No.
Feature
Phase
Document
Pipeline group
You can add, delete, modify, or move pipeline groups.
Commercial use
Grouping Pipelines
December 2023
No.
Feature
Phase
Document
Execution condition
You can configure execution conditions to control job executions.
Commercial use
September 2023
No.
Feature
Phase
Document
Release environment connecting with UCS resources
Release environments are connected with UCS for you to build cross-cloud CI/CD pipelines and achieve efficient and automated continuous delivery.
Commercial use
CodeArts Release Overview
August 2023
No.
Feature
Phase
Document
Triggering a pipeline through VS Code
A pipeline can be triggered through the CodeArts IDE extension.
Commercial use
May 2023
No.
Feature
Phase
Document
Adding the BranchCheck extension
You can use the extension to specify a target branch. If the current running branch lags behind the specified branch, the pipeline fails to run.
Commercial use
2
Microservice release
  • Environment variables, policy orchestration, and release resources complement the standard environment models.
  • Visualized processes and customizable templates for orchestration and release.
  • Layered microservice environments accessible by roles with assigned permissions.
  • Automated release and one-click stop/rollback protect O&M from human error for better reliability.
  • E2E release tracing covers historical versions, approval records, and operation records.
Commercial use
Creating a Release Environment
April 2023
No.
Feature
Phase
Document
Managing Groups
You can group and manage pipelines with the same features in a unified manner, improving operation efficiency.
Open beta testing
Managing Groups
February 2023
No.
Feature
Phase
Document
Enterprise CI/CD policy management
You can use policy templates to control pass conditions in each pipeline stage. This service displays red, green, and yellow indicators for you to block quality risks in advance. Our service provides enterprise-level and project-level hierarchical policy management modes to improve software release quality.
Commercial use
Rules and Policies
2
Cloud-native release management
You can use release sheets to manage events during changes, and roll back at one click.
Commercial use
Kubernetes Release Extensions
3
Microservice governance & change management
The DevOps agile change mode allows you to quickly and automatically merge and roll back code, release features on demand, and accelerate enterprise value monetization. In addition, the entire process of microservice requirements, development, test, release, and rollout can be traced from end to end.
Commercial use
Microservice Management
4
Dynamic and effective orchestration
Multi-step and multi-layer job nesting supports dynamic pipeline orchestration. Pipelines can be executed by code, as scheduled, upon changes, or manually.
Commercial use
Configuring a Pipeline
5
Pipeline extensions
Customizable extensions can be quickly integrated into pipelines for sharing and reuse within enterprises. The visualized UI allows you to generate extensions with low code.
Commercial use
Extensions
July 2022
No.
Feature
Phase
Document
Execution rollback
You can roll back execution.
Commercial use
Viewing a Pipeline
2
Execution records displayed by time
Execution records can be displayed by time. By default, executions in past 7 days are displayed. You can switch among past 7 days, 14 days, and 31 days.
Commercial use
Viewing a Pipeline
3
Stage configuration optimized
Always Run is added to stage configuration, indicating whether tasks in this stage are selected by default and cannot be canceled during pipeline running.
Commercial use
4
Permissions display optimized
The permission list can be displayed on multiple pages.
Commercial use
March 2022
No.
Feature
Phase
Document
The first official release
The functions is the first official release.
Commercial use
Progressive Knowledge
