Updated on 2025-11-07 GMT+08:00
COC and Other Services
Figure 1 shows the relationships between COC and other services.
Figure 1 COC and other services
Table 1 COC and other services
Service
Interaction with Other Services
Related Feature
Provides security monitoring information for you on the Overview page. Presents a comprehensive security overview from three perspectives: security score, security monitoring data, and security trend. It also allows for the creation of personalized security monitoring dashboards.
Security Score
Represents a resource monitoring data overview and also provides the resource alarm details. After Cloud Eye is integrated into COC, you can obtain and handle alarms generated on Cloud Eye in the fault management module of COC. You can also view metric data on Cloud Eye during chaos drills. To use these functions, enable Cloud Eye first.
Resource Monitoring
Integrating Cloud Eye
Chaos Drills
Application Operations Management (AOM)
Provides application monitoring dashboards. The dashboards configured on AOM can be displayed in COC. After AOM is integrated into COC, you can obtain and handle alarms generated on AOM in the fault management module of COC. You can also view metric data on AOM during chaos drills.
Viewing Application Monitoring
Integrating AOM
Chaos Drills
Elastic Cloud Server (ECS)
Provides ECSs for your operations like batch ECS management, script execution, job execution, and scheduled task management. You can also execute chaos drill tasks on ECSs.
Batch Operations on ECS Instances
Chaos Drills
Cloud Container Engine (CCE)
Provides CCE instances, so that you can execute chaos drills on these instances.
Chaos Drills
Application Performance Management (APM)
Enables you to obtain and handle alarms generated on APM, and transfer alarms to incidents as required in the fault management module of COC.
Integrating APM
Simple Message Notification (SMN)
Enables you to send notifications by SMS messages, emails, voice calls, WeCom, and DingTalk in scenarios like fault management and resource O&M in COC. To use these functions, enable the SMN service first.
Notification Management
RDS
Enables you to perform batch operations on RDS DB instances. You can also execute chaos drills on these RDS DB instances.
Batch Operations on RDS DB Instances
Chaos Drills
Bare Metal Server (BMS)
Provides BMSs for your operations like batch BMS management, script execution, job execution, and scheduled task management.
Batch Operations on BMSs
Object Storage Service (OBS)
Enables you to distribute and upload files to ECSs during resource O&M. To use these functions, purchase buckets on OBS first.
Executing Common Scripts
Provides FlexusL instances for your operations like batch FlexusL instance management, script execution, job execution, and scheduled task management. You can also execute chaos drill tasks on FlexusL instances.
Batch Operations on FlexusL Instances
Chaos Drills
Data Encryption Workshop (DEW)
Enables you to create encrypted parameters during resource O&M. To use this function, purchase keys on DEW first. During account management, you can use keys to protect your account passwords.
Encrypting Parameters
Account Management
