Help Center/ Cloud Operations Center/ Service Overview/ Constraints and Limitations
Updated on 2026-03-12 GMT+08:00
By June 2025, COC supports the following Huawei Cloud regions:
Cloud Operations Center (COC) is universally applicable. However, it is not supported in some special regions and scenarios (such as dedicated regions). If you have any requirements, contact COC service personnel.
Table 1 Huawei Cloud regions supported by Cloud Operations Center (COC)
Region
ME-Riyadh
CN-Hong Kong
AP-Singapore
AP-Bangkok
AP-Jakarta
CN East-Shanghai 1
CN East-Shanghai2
CN East2
CN North-Ulanqab1
CN East-Qingdao
CN North-Beijing1
CN North-Beijing4
CN South-Guangzhou
CN South-Shenzhen
TR-Istanbul
LA-Sao Paulo1
LA-Santiago
LA-Mexico City
LA-Mexico City2
CN Southwest-Guiyang1
AF-Cairo
AF-Johannesburg
When using COC, pay attention to the restrictions listed in Table 2.
Table 2 Restrictions on COC
Functional Module
Object
Restriction
Public
Managing patches, scripts, jobs, or ECSs
A maximum of 200 instances can be selected for a single operation task.
The timeout interval for executing a service ticket must be less than or equal to 86,400 seconds (24 hours).
Resource management
Installing OSs supported by UniAgent
Currently, the following Linux OS versions are supported:
  • EulerOS 2.2 (64-bit) for Tenant 20210227
  • EulerOS 2.3 (64-bit)
  • EulerOS 2.5 (64-bit) for Tenant 20210229
  • CentOS 7.2 (64-bit)
  • CentOS 7.3 (64-bit)
  • CentOS 7.4 (64-bit)
  • CentOS 7.5 (64-bit)
  • CentOS 7.6 (64-bit) for Tenant 20200925 (for resource image creation)
  • CentOS 7.6 (64-bit) for Tenant 20210227
  • CentOS 7.6 (64-bit) for Tenant 20210525
UniAgent client
If the CPU usage is greater than 10% or the memory is greater than 200 MB, the UniAgent client automatically restarts.
Installing a UniAgent
A maximum of 100 UniAgent hosts can be installed at a time.
Application management
Applications
An application must be within 5 layers.
Patch management
Patch baselines
A tenant can create a maximum of 50 (public baselines excluded) patch baselines.
Script management
Script content
The content of a custom script cannot exceed 100 KB.
Job management
Global parameters
The number of global parameters of a user-defined job cannot exceed 30.
War rooms
War room initiation rules
A maximum of 50 war room initiation rules can be created by a tenant.
Alarm conversion rules
A tenant can create a maximum of 50 alarm conversion rules.
Data source management
Data records
COC retains only the latest 10 records of integrated data sources.
Personnel management
Number of engineers
The number of personnel created by a tenant cannot exceed 50.
Shift schedule management
Roles
A maximum of 10 roles are allowed in a single shift scheduling scenario.
Account management
Resource types
Currently, ECSs can be managed.
Currently, account hosting (account import) is supported for the following types of resources:
  • ECSs
  • DCS instances
  • RDS instances
  • DMS instances
Account baselines
The number of baseline accounts is less than or equal to 30, and the number of components associated with the accounts is less than or equal to 100.
Currently, COC supports IAM login, IAM federated user login (including IAM user SSO and virtual user SSO), and login via IAM Identity Center. Login via IAM agencies is not supported. You can select one from these supported login methods to use COC features, such as ticket creation and review. For details about each login method, see Managing O&M Engineers.
