- What's New
- Function Overview
- Product Bulletin
Billing
- Billing Overview
- Billing Modes
- Billed Items
- Billing Examples
- Billing Mode Changes
- Renewing Subscriptions
- Bills
- Arrears
- Billing Termination
- Cost Management
Billing FAQ
- How Is CBR Billed?
- What Is the Billing Cycle of Pay-per-Use Vaults?
- How Do I Disable CBR?
- How Do I Unsubscribe from CSBS or VBS Resource Packages?
- Why Is a Message Displayed Indicating Insufficient User Rights When I Create a Policy?
- What Can I do If a Yearly/Monthly-Billed Vault Is About to Expire?
- How Do I Unsubscribe from a Vault?
- What Should I Do If the Fee Is Too High When I Expand the Capacity of a Vault?
- Why Are CBR Backups Displayed on the VBS Console?
- How Do I Purchase a CBR Replication Traffic Package?
- What Resources Do I Need to Implement Cross-Region Backup Replication?
- Why AM I Still Being Billed After a Resource is Deleted?
- Getting Started
User Guide
- Management permissions
Vault Management
- Overview
- Viewing a Vault
- Deleting a Vault
- Associating Resources to a Vault
- Dissociating Resources from a Vault
- Migrating Resources from a Vault
- Expanding Vault Capacity
- Reducing Vault Capacity
- Changing from Pay-per-Use to Yearly/Monthly
- Changing Vault Specifications
- Replicating a Vault Across Regions
- Managing Vault Tags
- Managing the Enterprise Projects of Vaults
- Enabling Backup Locking
- Backup Management
- Policy Management
- Organizational Policy Management
- Application-Consistent Backup
- File Backup (Supported Conditionally)
Restoring Data
- Restoring from a Cloud Server Backup
- Creating an Image from a Cloud Server Backup
- Restoring from a Cloud Disk Backup
- Creating a Disk from a Cloud Disk Backup
- Creating a File System from an SFS Turbo Backup
- Restoring from a Desktop Backup
- Restoring from a File Backup
- Restoring from a Hybrid Cloud Backup
- (Optional) Migrating Resources from CSBS/VBS
- Managing Tasks
- Cloud Eye Monitoring
- Recording CBR Operations Using CTS
- Quotas
- Appendix
Hybrid Cloud Backup Feature Guide
- Hybrid Cloud Backup
- Application Scenarios
- Constraints and Limitations
VMware Backup
- VMware Backup Process
- Downloading and Installing eBackup
- Configuring eBackup
- Adding a VMware Protected Environment
- Preparing for VMware Backup Storage
- Performing VMware Backup
- Restoring Data Using VMware Backups
- Managing a Protected VMware Environment
- Managing VMware Backup Storage
- Managing VMware Backups
- Common Operations
Best Practices
Using a Custom Script to Implement Application-Consistent Backup
- Using a Custom Script to Implement Consistent Backup for MySQL
- Using a Custom Script to Implement Consistent Backup for SAP HANA
- Using a Custom Script to Implement Consistent Backup for Other Linux Applications
- Verifying the Application-Consistent Backup Result
- Protecting SQL Server
- Troubleshooting a Custom Script Error
- Performing Periodic Recovery Drills Using the Backup Data
- Creating Backup Policies Based on Service Tiering
API Reference
- Before You Start
- API Overview
- Calling APIs
CBR APIs
- Tasks
- Protection
- Backups
- Backup Sharing
Vaults
- Creating a Vault
- Querying a Specified Vault
- Querying the Vault List
- Modifying a Vault
- Deleting a Vault
- Applying a Policy to a Vault
- Removing a Policy from a Vault
- Querying the Vault List in Other Regions
- Batch Modifying Vaults
- Setting Auto Backup for a Vault
- Creating a Yearly/Monthly Vault
- Querying Vault Usage of a Project
- File Backup
- Tags
- Policies
- Organizational Policies
- Metering
- Operations
- Restore Points
- Projects
- Application Cases
- Appendix
- SDK Reference
Troubleshooting
- Failed to Execute a Backup Task
- Failed to Delete a Backup
- Failed to Expand the Vault Capacity
- Failed to Attach Disks
- Data Disks Are Not Displayed After a Windows Server Is Restored
- Failed to Cancel Backup Sharing
- Failed to Download or Install the Agent Required by Application-Consistent
- Failed to Install the Agent on Windows
- Failed to Implement Application-Consistent Backup
- A Server Created Using an Image Enters Maintenance Mode After Login
- Failed to Migrate VMware Backups to the Cloud
- Failed to Restore a VMware Backup to a Cloud Server
- An Error Message Is Displayed Indicating that the Path of a Storage Unit Is Invalid
- Failed to Import an eBackup Image Template, with an Error Displayed Indicating That the File Is Invalid
- The Download Dialog Box Disappears When I Download eBackup on a VMware VM
- File Backup Failed Due to Inconsistent Time Between Backup Client and UTC Time
- Concepts
Billing
- Can I Change a Server Backup Vault to a Disk Backup Vault or the Other Way Around?
- What Charges Will I Incur When Using a Backup to Create an Image?
Backup
- Do I Need to Stop the Server Before Performing a Backup?
- Can I Back Up a Server Deployed with Databases?
- How Can I Distinguish Automatic Backups From Manual Backups?
- Can I Choose to Back Up Only Some Partitions of a Disk?
- Does CBR Support Cross-Region Backup?
- How Do I Migrate Server Data Across Regions Using Server Backups?
- Can I Back Up Two Disks to One Target Disk?
- How Do I Replicate a Disk to the Same AZ in a Region as the Source Disk?
- Can I Migrate Backups Between Vaults?
- Can I Use Its Backup for Restoration After a Resource Is Deleted?
- How Many Backups Can I Create for a Resource?
- Can I Use an Incremental Backup to Restore Data After a Full Backup Is Deleted?
- Can I Stop an Ongoing Backup Task?
- How Do I Reduce the Vault Space Occupied by Backups?
- How Do I View the Size of Each Backup?
- How Do I View My Backup Data?
- How Long Will My Backups Be Kept?
- How Do I Implement Periodic Full Backups for My Resources?
- How Do I Query Resources that Have not Been Backed Up?
- Is There Any Requirement on the Network Bandwidth During Data Backup?
Capacity
- How Large of a Vault Do I Need?
- Why Is My Backup Size Larger Than My Disk Size?
- What Can I Do If the Vault Capacity Is Not Enough?
- Why Does the Used Capacity of a Vault Change Only Slightly After I Deleted Unwanted Backups?
- Will Backup Continue If the Usage of a Vault Reaches the Upper Limit?
- How Do I Adjust the Vault Capacity Alarm Threshold?
Restoration
- Do I Need to Stop the Server Before Restoring Data Using Backups?
- Can I Use a System Disk Backup to Recover an ECS?
- Do I Need to Stop the Server Before Restoring Data Using Disk Backups?
- Can a Server Be Restored Using Its Backups After It Is Changed?
- Can a Disk Be Restored Using Its Backups After Its Capacity Is Expanded?
- What Can I Do if the Password Becomes a Random One After I Use a Backup to Restore a Server or Use an Image to Create a Server?
- What Changes Will Be Made to the Original Backup When I Use the Backup to Restore a Server?
- How Do I Restore Data to a New Server?
- How Do I Restore a Data Disk Backup to a System Disk?
- Can I Use CBR to Restore Data to Any Point When the Data Was Backed Up?
- Can I Stop an Ongoing Restoration Task?
Policies
- How Do I Configure Automatic Backup for a Server or Disk?
- Why the New Retention Rule I Changed Is Not Applied?
- How Do I Back Up Multiple Resources at a Time?
- How Do I Retain My Backups Permanently?
- How Can I Cancel Auto Backup or Auto Replication?
- How Can I Have the System Automatically Delete Backups That I No Longer Need?
- Why Aren't My Backups Deleted Based on the Retention Rule?
- Optimization
- Is There a Quota for CBR Vaults?
- Can I Merge My Vaults?
- How Do I Delete a Backup That Has Been Used to Create an Image While Retaining the Image?
- Can I Export Disk Backup Data to Another Server?
- Why Do I Need a Vault to Accept the Image Shared to Me?
- Can I Download Backup Data to a Local PC?
- How Do I Copy Disk Data to Another Account?
- Videos
More Documents
- Getting Started
- Vault Management
- Backup Management
- Policy Management
- Restoring Data
- Managing Tasks
- Monitoring
- Quotas
- Concepts
- Billing
Backup
- Will the Server Performance Be Affected If I Delete Its Backups?
- Capacity
Restoration
Policies
- How Can I Cancel Auto Backup?
- Optimization
- Troubleshooting Cases
- Appendix
- API Reference (ME-Abu Dhabi Region)
Best Practices (ME-Abu Dhabi Region)
- Verifying the Application-Consistent Backup Result (Linux)
- Verifying the Application-Consistent Backup Result (Windows)
- Protecting SQL Server in Failover Cluster Mode
- Protecting SQL Server in Always on Availability Groups Mode
- Change History
User Guide (Paris)
- Getting Started
- Vault Management
- Backup Management
- Policy Management
- Restoring Data
- Managing Tasks
- Monitoring
- Auditing
- Quotas
- Concepts
Backup
- Capacity
Restoration
Policies
- Optimization
- Appendix
- API Reference (Paris)
Best Practices (Paris)
- Change History
- Getting Started
- Permissions Management
- Vault Management
- Backup Management
- Policy Management
- Restoring Data
- Managing Tasks
- Monitoring
- Quotas
- Concepts
Backup
Restoration
- Policies
- Others
- Appendix
- API Reference (Kuala Lumpur Region)
Best Practices (Kuala Lumpur Region)
- Change History
User Guide (Ankara Region)
- Getting Started
- Vault Management
- Backup Management
- Policy Management
- Restoring Data
- Managing Tasks
- Monitoring
- Quotas
- Concepts
Backup
- Capacity
Restoration
- Policies
- Others
- Appendix
- API Reference (Ankara Region)
Best Practices (Ankara Region)
- Change History
- Glossary
Show all
Function Overview
- ALL
- CBR
- Cloud Disk Backup
- Cloud Server Backup
- SFS Turbo Backup
- Desktop Backup
- File Backup
- Policy-driven Data Backup
- Restoring Data Using a Backup
- Sharing a Backup
- Using a Backup to Create a Disk
- Using a Backup to Create an Image
- Using a Backup to Create a File System
- Automatic Resource Association
- Migrating a Resource
- Auto Capacity Expansion
- Cross-region Replication of Backups
- Backup Encryption
- Backup Locking
- Monitoring
- Auditing
- Yearly/Monthly Subscription
- Pay-per-Use Billing
OBS 2.0 Supported
Cloud Backup and Recovery (CBR) enables you to back up Elastic Cloud Servers (ECSs), Bare Metal Servers (BMSs), Elastic Volume Service (EVS) disks, SFS Turbo file systems,and on-premises VMware virtual environments with ease. In case of a virus attack, accidental deletion, or software or hardware fault, you can restore data to any point in the past when the data was backed up.
CBR protects your services by ensuring the security and consistency of your data.Released in: CN North-Beijing4, CN East-Shanghai1, CN South-Guangzhou, CN Southwest-Guiyang1, CN-Hong Kong, AP-Bangkok, AP-Singapore, AP-Jakarta, AF-Johannesburg, TR-lstanbul, LA-Mexico City1, LA-Mexico City2, LA-Sao Paulo1, LA-Santiago
OBS 2.0 Supported
CBR provides snapshot-based data protection for EVS disks. You can use CBR to back up a single disk on a server to protect data on the disk.
Backup/Restoration objects: one or more specified disks (system or data disks)
Recommended scenario: Only data disks need to be backed up, because the system disk does not contain personal data.
Advantages: Backup cost is reduced without compromising data security.Released in: CN North-Beijing4, CN East-Shanghai1, CN South-Guangzhou, CN Southwest-Guiyang1, CN-Hong Kong, AP-Bangkok, AP-Singapore, AP-Jakarta, AF-Johannesburg, TR-lstanbul, LA-Mexico City1, LA-Mexico City2, LA-Sao Paulo1, LA-Santiago
OBS 2.0 Supported
CBR protects data based on multi-disk consistency snapshots for ECSs and BMSs. You can use CBR to back up an entire server to protect data on the server. You are advised to use cloud server backup in scenarios that require high data consistency, such as RAID clusters.
Backup/Restoration object: all disks (system and data disks) on a server
Recommended scenario: An entire cloud server needs to be protected.
Advantages: All disks on a server are backed up at the same time, ensuring data consistency.Released in: CN North-Beijing4, CN East-Shanghai1, CN South-Guangzhou, CN Southwest-Guiyang1, CN-Hong Kong, AP-Bangkok, AP-Singapore, AP-Jakarta, AF-Johannesburg, TR-lstanbul, LA-Mexico City1, LA-Mexico City2, LA-Sao Paulo1, LA-Santiago
OBS 2.0 Supported
You can use CBR to back up SFS Turbo file systems and then use the backups to create new SFS Turbo file systems, preventing the loss of important data.
Backup/Restoration object: SFS Turbo file systems
Recommended scenario: Data in the SFS Turbo file systems needs to be protected.
Advantages: Backups and original file systems are stored separately. You can use a backup to create a new file system.Released in: CN North-Beijing4, CN East-Shanghai1, CN South-Guangzhou, CN Southwest-Guiyang1, CN-Hong Kong, AP-Bangkok, AP-Singapore, AP-Jakarta, AF-Johannesburg, TR-lstanbul, LA-Mexico City1, LA-Mexico City2, LA-Sao Paulo1, LA-Santiago
OBS 2.0 Supported
You can use CBR to back up a desktop and then use the backups to restore the desktop to its state when the backup was created., preventing the loss of important data.
Backup/Restoration object: Entire Workspace desktop systems, including all disks.
Recommended scenario: Data in the desktop needs to be protected.
Advantages: Desktop data and their backups are stored separately, and the backups can be used to create new desktops.Released in: LA-Santiago, LA-Sao Paulo1, LA-Mexico City2, CN North-Beijing4, CN East-Shanghai1, CN South-Guangzhou, CN Southwest-Guiyang1, CN-Hong Kong, AF-Johannesburg
OBS 2.0 Supported
You can use CBR to synchronize the backups of VMware VMs to the cloud, and then manage the backups on the cloud and restore data to other cloud servers using the backup data.
Hybrid cloud backup includes:
VMware backup: CBR synchronizes the backups of on-premises VMware VMs.Released in: CN North-Beijing4, CN East-Shanghai1, CN South-Guangzhou, AP-Bangkok, AP-Singapore, AP-Jakarta, AF-Johannesburg, LA-Sao Paulo1, LA-Santiago
OBS 2.0 Supported
There are three backup types in terms of backup consistency:
Inconsistent backup: Files and disks are backed up at different points in time. CBR's server backup uses the consistency snapshot technology for disks to protect data of ECSs and BMSs. If you back up multiple EVS disks separately, the backup time points of the EVS disks are different. As a result, the backup data of the EVS disks is inconsistent.
Crash-consistent backup captures data existing on disks upon backup and backs up files or disks at the same point in time, without backing up memory data and quieting application systems. Backup consistency of application systems is not ensured. Though the application consistency is not ensured, disks, such as chkdsk, will be checked upon operating system re-startup to restore damaged data and log rollback will be performed on databases to keep data consistent.
Application-consistent backup: Files and disks are backed up at the same point in time, including memory data, to ensure application system consistency.
CBR supports both crash-consistent backup and application-consistent backup (also called database backup).
If a MySQL or SAP HANA database is deployed on a server, you can use the application-consistent backup function of CBR to back up the server data and application cache. Crash-consistent backup backs up only data and some application caches without interrupting services. When a system fails or data loss occurs, you can use an application-consistent backup to quickly restart services. A crash-consistent backup, however, may fail to restore some application configurations.
Released in: CN North-Beijing4, CN East-Shanghai1, CN South-Guangzhou, CN-Hong Kong, AP-Bangkok, AP-Singapore, AF-Johannesburg, LA-Mexico City2, LA-Sao Paulo1, LA-Santiago
OBS 2.0 Supported
CBR provides file backup which allows you to back up files and directories on your cloud servers and on-premises hosts, so you do not have to back up your entire servers or disks. Cloud servers can be Huawei Cloud servers or their counterparts from a third-party cloud. If an accidental deletion or a software/hardware fault occurs on your files, you can restore data to any time in the past when a backup was created.
Released in: CN North-Beijing4, CN East-Shanghai1, CN South-Guangzhou, CN Southwest-Guiyang1, CN-Hong Kong, AP-Bangkok, AP-Singapore, AF-Johannesburg
CBR supports one-off backup and periodic backup. A one-off backup task is manually created by users and takes effect only once. Periodic backup tasks are automatically executed based on a user-defined backup policy.
A backup policy allows a vault to automatically execute backup tasks at a specified interval. Periodic backups can be used to restore data quickly against data corruption or loss.Released in: CN North-Beijing4, CN East-Shanghai1, CN South-Guangzhou, CN Southwest-Guiyang1, CN-Hong Kong, AP-Bangkok, AP-Singapore, AP-Jakarta, AF-Johannesburg, TR-lstanbul, LA-Mexico City1, LA-Mexico City2, LA-Sao Paulo1, LA-Santiago
You can use CBR to quickly restore data in the following scenarios to ensure service security and reliability.
Hacker attacks and virus infection
CBR can instantly restore data to the latest backup point at which the server has not been affected by hacker attacks and viruses.
Accidental deletion
CBR can instantly restore a server or disk to the backup point prior to the accidental deletion.
Application update errors
CBR can instantly restore a server or disk to the backup point prior to the application update.
System breakdown
CBR can instantly restore a server to the backup point prior to the system breakdown.Released in: CN North-Beijing4, CN East-Shanghai1, CN South-Guangzhou, CN Southwest-Guiyang1, CN-Hong Kong, AP-Bangkok, AP-Singapore, AP-Jakarta, AF-Johannesburg, TR-lstanbul, LA-Mexico City1, LA-Mexico City2, LA-Sao Paulo1, LA-Santiago
OBS 2.0 Supported
You can share a server or disk backup with other projects. The shared backups can be used to create servers.
Backups can be shared only among users in the same region.
A backup recipient can choose whether to accept the backup. After accepting the backup, the recipient can use the backup to create a new server.
Encrypted backups cannot be shared. Backups cannot be shared across regions. Projects to which a backup is shared must be in the same region as the backup.Released in: CN North-Beijing4, CN East-Shanghai1, CN South-Guangzhou, CN Southwest-Guiyang1, CN-Hong Kong, AP-Bangkok, AP-Singapore, AP-Jakarta, AF-Johannesburg, TR-lstanbul, LA-Mexico City1, LA-Mexico City2, LA-Sao Paulo1, LA-Santiago
OBS 2.0 Supported
You can use a disk backup to create a disk. After the disk is created, data on the new disk is the same as that in the disk backup.
After a new disk is created using the backup data of a system disk, the new disk can only be mounted to the cloud server as a data disk and cannot be mounted as a system disk.
You can choose the AZ to which the backup source disk belongs, or you can choose a different AZ.
The newly created disk must be at least as large as the backup source disk.
You can create a disk of any type regardless of the backup's disk type.
Batch creation is not supported when you use backup data to create EVS disks. Quantity can only be 1.Released in: CN North-Beijing4, CN East-Shanghai1, CN South-Guangzhou, CN Southwest-Guiyang1, CN-Hong Kong, AP-Bangkok, AP-Singapore, AP-Jakarta, AF-Johannesburg, TR-lstanbul, LA-Mexico City1, LA-Mexico City2, LA-Sao Paulo1, LA-Santiago
OBS 2.0 Supported
CBR allows you to create images using ECS backups. You can use the images to provision ECSs to rapidly restore service operating environments.
Images created from a backup are the same, so CBR allows you to use a backup to create only one full-ECS image that contains the whole data of the ECS's system disk and data disks, in order to save the image quota. After an image is created, you can use the image to provision multiple ECSs in a batch.
A backup with an image created cannot be deleted manually or automatically. If you want to delete such a backup, delete its image first. If a backup is automatically generated based on a backup policy and the backup has been used to create an image, the backup will not be counted as a retained backup and will not be deleted automatically.
A backup is compressed when it is used to create an image. Therefore, the size of the generated image is smaller than that of the backup.Released in: CN North-Beijing4, CN East-Shanghai1, CN South-Guangzhou, CN Southwest-Guiyang1, CN-Hong Kong, AP-Bangkok, AP-Singapore, AP-Jakarta, AF-Johannesburg, TR-lstanbul, LA-Mexico City1, LA-Mexico City2, LA-Sao Paulo1, LA-Santiago
OBS 2.0 Supported
You can use a file system backup to create a new file system. After it is created, data on the new file system is the same as that in the backup.
OBS 2.0 Supported
Backup vaults support automatic association with resources that are not backed up. After successful association, resources will be backed up according to the backup policy applied to the vault.
Released in: CN East-Shanghai1, AF-Johannesburg, LA-Mexico City1, LA-Santiago
OBS 2.0 Supported
Migrating a resource means that you dissociate a resource from a vault and then associate it to another vault. All backups of the resource will be migrated to the destination vault.
OBS 2.0 Supported
You can expand the size of a vault if its total capacity is insufficient.
OBS 2.0 Supported
If you want a vault to be automatically expanded when its capacity is used up, enable auto capacity expansion.
If this function is enabled, the vault capacity will be automatically expanded to 1.25 times its current capacity when its capacity is used up.
Released in: CN North-Beijing4, CN East-Shanghai1, CN South-Guangzhou, CN Southwest-Guiyang1, CN-Hong Kong, AP-Bangkok, AP-Singapore, AP-Jakarta, AF-Johannesburg, LA-Mexico City1, LA-Mexico City2, LA-Sao Paulo1, LA-Santiago
OBS 2.0 Supported
You can reduce the size of a vault if its total capacity is too much for you.
Only pay-per-use vaults can have their capacity reduced.
Released in: All
OBS 2.0 Supported
Server backup vaults and server replication vaults both have two specifications: those for server backups/replicas and those for application-consistent backups/replicas.
- Server backups are backups of non-database servers.
- Application-consistent backups are backups of database servers.
If you need to back up database servers, change the specifications of the target vault from server backup to application-consistent backup.
You can only change the specifications of a vault from server backup to application-consistent backup, but not the other way around.
Released in: CN North-Beijing4, CN East-Shanghai1, CN South-Guangzhou, CN-Hong Kong, AP-Bangkok, AP-Singapore, AF-Johannesburg, LA-Santiago
OBS 2.0 Supported
You can add, edit, or delete tags of a vault. Vault tags are used to filter and manage vaults only.
OBS 2.0 Supported
If you need to modify the enterprise project of a vault, go to the Enterprise Management page to move the vault from the original enterprise project to a new one.
Released in: CN North-Beijing4, CN East-Shanghai1, CN South-Guangzhou, CN Southwest-Guiyang1, CN-Hong Kong, AP-Bangkok, AP-Singapore, AP-Jakarta, AF-Johannesburg, TR-lstanbul, LA-Mexico City1, LA-Sao Paulo1, LA-Santiago
OBS 2.0 Supported
CBR enables you to replicate server backups and SFS Turbo backups from one region to another. In the destination region:
- Replicas of server backups can be used to create images and provision servers.
- Replicas of SFS Turbo backups can be used to create file systems.
With cross-region replication, you can quickly deploy services in a different region. Data on the new resource in the destination region is the same as that on the original resource when you took the backup.
You can replicate backups in either of the following methods on CBR Console:
- Select a backup from the backup list and manually perform a replication.
- Select a backup vault and manually replicate it. Alternatively, you can configure a replication policy to periodically replicate backups that have not been replicated or failed to be replicated to the destination region.
Released in: CN North-Beijing4, CN North-Beijing1, CN North-Ulanqab1, CN South-Guangzhou, CN East-Shanghai1, CN East-Shanghai2, CN-Hong Kong, AP-Bangkok, AP-Singapore, LA-Mexico City2, LA-Santiago, LA-Lima1, LA-Sao Paulo1
OBS 2.0 Supported
CBR will identify whether the selected disk is encrypted.
If the disk to be backed up is encrypted, the backup will also be automatically encrypted. The encryption attribute of backups cannot be changed.
Released in: AP-Singapore
OBS 2.0 Supported
To prevent the backup data from being deleted by mistake or maliciously, you can enable backup locking for vaults to improve data security.
Once enabled, all backups in the vault enter the WORM (write once, read many) status. No one can delete the backups that are in their retention periods.
Released in: All
OBS 2.0 Supported
You can manage backup policies for a given organization. The organization administrator or delegated CBR administrator can centrally create and configure organizational policies for member accounts in the organization.All member accounts in the organization can use the created organizational policies.
CBR will be enabled as a trusted service when a management account creates organizational policies. After CBR is enabled as a trusted service for Organizations, CBR can obtain information about OUs and member accounts to provide organization-level management and backup services for the entire organization.
Released in: AF-Johannesburg, CN-Hong Kong, AP-Bangkok, AP-Singapore, AP-Jakarta, CN East-Shanghai2, CN East-Shanghai1, CN East2, CN North-Beijing1, CN North-Beijing2, CN North-Beijing4, CN North-Ulanqab1, CN South-Guangzhou, CN East-Qingdao, CN Southwest-Guiyang1, LA-Mexico City1, LA-Mexico City2, LA-Santiago, ME-Riyadh, TR-Istanbul, AF-Cairo
OBS 2.0 Supported
You can use the console or APIs provided by Cloud Eye to query the metrics generated for CBR.
OBS 2.0 Supported
You can use Cloud Trace Service (CTS) to trace operations in CBR.
OBS 2.0 Supported
Yearly/monthly is a prepaid billing mode. You are billed based on the subscription duration you specify. This mode provides lower prices and is ideal when the resource use duration is predictable.
Released in: CN Southwest-Guiyang1, CN-Hong Kong, AP-Bangkok, AP-Singapore, AP-Jakarta, AF-Johannesburg, TR-lstanbul, LA-Mexico City1, LA-Mexico City2, LA-Sao Paulo1, LA-Santiago
OBS 2.0 Supported
Pay-per-use is a postpaid billing mode. You are billed based on your resource usage. With this mode, you can increase or delete resources at any time. Fees are deducted from your account balance.
