Recording CBR Operations Using CTS
You can use Cloud Trace Service (CTS) to trace operations in CBR.
CTS has been enabled.
Key Operations Recorded by CTS
| Operation | Resource Type | Trace Name |
| Creating a backup | backup | createBackup |
| Deleting a backup | backup | deleteBackup |
| Restoring from a backup | backup | restoreBackup |
| Updating a backup | backup | updateBackup |
| Replicating a backup | backup | replicateBackup |
| Importing a backup | backup | importBackup |
| Synchronizing a backup | backup | syncBackup |
| Registering a backup image | backup | registerBackupImage |
| Unregistering a backup image | backup | unregisterBackupImage |
| Querying a specific backup | backup | showBackupDetail |
| Querying all backups | backup | listBackups |
| Querying backup metadata | backup | showBackupMeta |
| Querying backup details | backup | showBackupDetailByProvider |
| Creating a backup recipient | backup | createBackupMember |
| Updating the status of a backup recipient | backup | updateBackupMember |
| Deleting a backup recipient | backup | deleteBackupMember |
| Querying backup recipients | backup | queryBackupMembers |
| Querying details about the backup recipient | backup | showBackupMemberDetail |
| Adding a backup path | agent | addAgentPath |
| Removing a backup path | agent | removeAgentPath |
| Updating an Agent | agent | updateAgent |
| Deleting an Agent | agent | deleteAgent |
| Registering an Agent | agent | registerAgent |
| Querying an Agent | agent | showAgentById |
| Querying all Agents | agent | listAgents |
| Creating an organizational policy | organization_policy | createOrganizationPolicy |
| Updating an organizational policy | organization_policy | updateOrganizationPolicy |
| Deleting an organizational policy | organization_policy | deleteOrganizationPolicy |
| Querying organizational policies | organization_policy | listOrganizationPolicies |
| Querying a specific organizational policy | organization_policy | showOrganizationPolicyById |
| Querying the application of an organizational policy | organization_policy | showOrganizationPolicyDetail |
| Creating a policy | policy | createPolicy |
| Modifying a policy | policy | updatePolicy |
| Deleting a policy | policy | deletePolicy |
| Querying a policy | policy | showPolicyById |
| Querying policies | policy | listPolicy |
| Creating a checkpoint | vault | createVaultBackup |
| Replicating a checkpoint | vault | replicateVaultBackup |
| Synchronizing a checkpoint | vault | syncVaultBackup |
| Querying a checkpoint | vault | showCheckpoint |
| Adding or deleting vault tags in batches | vault | bulkCreateOrDeleteVaultTag |
| Adding tags to a vault | vault | createVaultTag |
| Deleting tags from a vault | vault | deleteVaultTag |
| Querying vault resources | vault | showVaultInstance |
| Querying tags of a vault | vault | showVaultTag |
| Querying tags of a project | vault | listVaultTags |
| Creating a vault | vault | createVault |
| Modifying a vault | vault | updateVault |
| Deleting a vault | vault | deleteVault |
| Removing resources | vault | removeResources |
| Adding resources | vault | addResources |
| Migrating resources | vault | migrateResources |
| Setting whether to enable automatic backup for a vault | vault | setResources |
| Associating a policy with a vault | vault | associatePolicy |
| Disassociating a policy from a vault | vault | dissociatePolicy |
| Batch updating vaults | vault | updateVault |
| Creating a yearly/monthly vault | vault | createVault |
| Updating vault capacity | vault | syncVaultCapacity |
| Querying vaults | vault | listVaults |
| Querying a specific vault | vault | showVault |
| Querying the vaults in other regions | vault | listVaultsExternal |
| Querying vault capacity | vault | showVaultSummaryCapacity |
| Querying a single task | task_job | showTaskOperateLog |
| Querying tasks | task_job | listTaskOperateLogs |
| Querying protectable resources | protectable | listProtectableInstances |
| Querying the Agent status | protectable | queryAgentStatus |
| Querying a specific protectable resource | protectable | showProtectableInstance |
| Querying the replication capability | protectable | showRepCapabilities |
| Migrating data for a tenant | migrate | createMigrate |
| Querying the migration | migrate | showMigrate |
| Querying tenant information | migrate | showDomainProjectInfo |
| Querying a tenant's projects | migrate | listDomainProjects |
| Querying a tenant's project information | migrate | showDomainProjects |
| Querying capacity statistics | meters | showStorageCapacity |
| Querying metering data | meters | listMeters |
| Querying backup resources | meters | listBackupResources |
| Querying the capacity statistics of a specific resource | meters | showStorageUsageByResource |
| Changing from pay-per-use to yearly/monthly | vault | changeChargeMode |
| Granting access to a bucket | backup | authorizeBackupBucket |
| Querying bucket permissions | backup | showBackupBucketAuthorizations |
| Querying backup metadata | backup | showBackupMetaDetail |
Viewing Audit Logs
For how to view audit logs, see section "Querying Real-Time Traces" in the Cloud Trace Service User Guide.
Disabling or Enabling a Tracker
The following procedure illustrates how to disable an existing tracker on the CTS console. After the tracker is disabled, CTS will stop recording operations, but you can still view existing operation records.
- Log in to the CTS console.
- In the upper left corner, click and select a region.
- Click Service List and choose Management & Governance > Cloud Trace Service.
- Choose Tracker List in the navigation pane.
- In the tracker list, click Disable in the Operation column.
- Click OK.
- After the tracker is disabled, the available operation changes from Disable to Enable. To enable the tracker again, click Enable and then click OK. CTS will start recording operations again.
