Creating an Image from a Cloud Server Backup
CBR allows you to create images using ECS backups. You can use the images to provision ECSs to rapidly restore service running environments.
You can also use server backups to create images and then provision servers to restore data if your servers were accidentally deleted.
- The following operations have been performed:
Notes
- Images created using a backup are the same, so CBR allows you to use a backup to create only one full-ECS image that contains the whole data of the system disk and data disks of the ECS, in order to save the image quota. After an image is created, you can use the image to provision multiple ECSs in a batch.
- A backup with an image created cannot be deleted directly. To delete such a backup, delete its image first. If a backup is automatically generated based on a backup policy and the backup has been used to create an image, the backup will not be counted as a retained backup and will not be deleted automatically.
- A backup is compressed when it is used to create an image, so the size of the generated image may be smaller than the backup size.
Billing
- If you use a cloud server backup to create an image, the KooGallery image and some public images are charged.
- For more details, see Image Management Service Billing.
- In CloudPond scenarios, cloud servers cannot be created using the images created from cloud server backups.
- You can create an image from a backup only when the backup is in the Available state or in the Creating state with "Image can be created" displayed.You can create an image from a backup only when the backup is in the Available state, in the Creating (available in the AZ) state, or in the Creating state with "Image can be created" displayed.
- Once backup creation starts, the backup enters the Creating state. After a period of time, a message stating "Image can be created" is displayed under Creating. In this case, the backup can be used for creating an image, even though it is still being created and cannot be used for restoration.
- When the backup status is Creating (available within the AZ), you can use the backup to create images. Images can only be created in the same AZ as the server. If the AZ is faulty, the full-ECS image creation may fail or the image may be unavailable.
- When the backup status is Creating (available within the AZ) and the backup is being created or used to restore data, the backup cannot be used to create an image.
- The backup must contain the system disk data.
- Only ECS backups can be used to create images. BMS backups cannot be used to create images.
- Log in to the CBR console. Click
in the upper left corner and select a region. - Click the Backups tab. Locate the desired backup. For details, see Viewing a Backup.
- In the row of the backup, choose More > Create Image.
- Create an image by referring to Creating a Full-ECS Image from a CBR Backup in the Image Management Service User Guide.
- Use the image to provision ECSs when needed. For details, see Creating an ECS from an Image in the Image Management Service User Guide.
Helpful Links
- A server is created using the image of a cloud server backup. However, upon login to the server, the server enters maintenance mode and cannot be used. For details, see A Server Created Using an Image Enters Maintenance Mode After Login.
- What Can I Do If the Password Is Reset to a Random One After I Use a Backup to Restore a Server or Use an Image to Create a Server?
