Viewing a Backup
In the backup list, you can set search criteria to filter backups and view their details. The results contain backup tasks that are running or have completed.
At least one backup task has been created.
- Log in to the CBR console. Click
in the upper left corner and select a region. - Click the Backups tab and set filter criteria to view the backups.
The last active time displayed in the backup client list shows the last time the Agent was detected as normal.
- You can search for backups by selecting a status from the All statuses drop-down list above the backup list. Table 1 describes the backup statuses.
Table 1 Backup statuses Status
Status Attribute
All statuses
All backups are displayed if this value is selected.
Available
A stable state
A stable backup state after the backup is created.
Most operations can be performed on a backup in this state.
Creating
An intermediate state
An intermediate state of a backup from the start of a backup job to the completion of this job.
In the Tasks list, a progress bar is displayed for a backup task in this state. If the progress bar remains unchanged for an extended time, an exception has occurred. Contact customer service.
Restoring
An intermediate state when using the backup to restore data.
In the Tasks list, a progress bar is displayed for a restoration task in this state. If the progress bar remains unchanged for an extended time, an exception has occurred. Contact customer service.
Deleting
An intermediate state from the start of backup deletion to its completion.
In the Tasks list, a progress bar is displayed for a deletion task in this state. If the progress bar remains unchanged for an extended time, an exception has occurred. Contact customer service.
Error
A stable state
A backup enters the Error state when an exception occurs.
A backup in this state cannot be used for restoration, and must be deleted manually. If manual deletion fails, contact customer service.
- You can search for backups by clicking Advanced Search above the backup list.
You can search by specifying a backup name, backup ID, backup status, server name, server ID, server type, protection type, or the creation date.
Figure 1 Filtering backups
- You can search for backups by selecting an enterprise project in the search area above the backup list.
- Click Export above the backup list to export the cloud backup list.
- Click the backup name to view details about the backup.
Checking RDS Backups
in the upper left corner and select a region. - In the navigation pane, choose Cloud Database Backups. On the Instances tab, click View Backups in the Operation column to view the backups.
