Help Center/ Cloud Backup and Recovery/ User Guide/ Data Restoration/ Creating a Disk from a Cloud Disk Backup
Updated on 2026-11-26 GMT+08:00
If an EVS disk encounters data loss, an exception, or a fault, you can use a backup of the disk to create a new EVS disk to quickly restore service data. Backups can also be used to create new disks in O&M scenarios such as cross-AZ data migration and rapid setup of test and verification environments. Data on the new disk is restored to the exact state of the source disk at the time of the backup, efficiently meeting data restoration and service reuse requirements.
Disks created using system disk backups can only be used as data disks on servers. They cannot be used as system disks.
Disk backups can only be used to create EVS disks, not servers.
Billing
In CloudPond scenarios, EVS backups cannot be used to create new EVS disks.
  1. Log in to the CBR console. Click in the upper left corner and select a region.
  2. Click the Backups tab. Locate the desired backup. For details, see Viewing a Backup.
  3. Click Create Disk in the Operation column of the backup. The button is available only when the backup status is Available. The Create Disk page is displayed.
  4. Configure the disk parameters.
    For details, see the descriptions in the Parameter description table in section "Purchasing an EVS Disk" in the Elastic Volume Service User Guide.
    Pay attention to the following:
    • You can choose the AZ to which the backup source disk belongs, or a different AZ.
    • The new disk must be at least as large as the backup's source disk.
      If the capacity of the new disk is greater than that of the backup's source disk, format the additional space by following the steps provided in section "Extending Disk Partitions and File Systems" of the Elastic Volume Service User Guide.
    • You can create a disk of any type regardless of the backup's source disk type.
  5. Click Submit.
    You can choose Pay-per-use or Yearly/Monthly for Billing Mode. The following steps use the Yearly/Monthly billing as an example.
  6. Confirm the disk information and click Submit.
  7. Make the payment and click OK.
  8. Go back to the disk list. Check whether the disk is successfully created.
    You will see the disk status progress through the following phases: Creating → Available → Restoring → Available. Because Instant Restore is supported, the Restoring phase may be very brief and easy to miss. When the status changes from Creating to Available, the disk has been successfully created. When the status changes from Restoring to Available, the backup data has been successfully restored to the disk.
